查看: 23954|回复: 101
【Intuitive Analog Circuit Design.pdf】
发表于 2008-8-3 11:31:48 | 显示全部楼层 |阅读模式
Preface ............................................................................................................xi
Chapter 1: Introduction and Motivation .......................................................1
The Need for Analog Designers ...............................................................................1
Some Early History of Technological Advances in Analog  Integrated Circuits ......2
Digital vs. Analog Implementation: Designer!ˉs Choice ..........................................
So, Why Do We Become Analog Designers? ..........................................................8
Note on Nomenclature in this Text ..........................................................................9
Note on Coverage in this Book ................................................................................9
References ..............................................................................................................10
U.S. Patents ............................................................................................................12
Chapter 2: Review of Signal-Processing Basics ...........................................13
Review of Laplace Transforms, Transfer Functions and Pole-Zero Plots .............13
First-Order System Response ................................................................................15
Second-Order Systems ...........................................................................................23
Review of Resonant Electrical Circuits .................................................................33
Use of Energy Methods to Analyze Undamped Resonant Circuits .......................34
Transfer Functions, Pole/Zero Plots and Bode Plots .............................................36
Risetime for Cascaded Systems .............................................................................37
Chapter 2 Problems ................................................................................................38
References ..............................................................................................................42
Chapter 3: Review of Diode Physics and the Ideal
(and Later, Nonideal) Diode ....................................................................43
Current Flow in Insulators, Good Conductors and Semiconductors .....................43
Electrons and Holes ...............................................................................................45
Drift, Diffusion, Recombination and Generation ...................................................48
Effects of Semiconductor Doping ..........................................................................53
PN Junction Under Thermal Equilibrium ..............................................................54
PN Junction Under Applied Forward Bias .............................................................57
vii
Thompson Book.indb   vii 3/20/2006   11:33:32 AM
Contents
Reverse Biased Diode ............................................................................................61
Ideal Diode Equation .............................................................................................62
Charge Storage in Diodes ......................................................................................63
Charge Storage in the Diode Under Forward Bias ..
Reverse Recovery in Bipolar Diodes .....................................................................65
Reverse Breakdown ...............................................................................................66
Taking a Look at a Diode Datasheet ......................................................................67
Some Quick Comments on Schottky Diodes .........................................................70
Chapter 3 Problems ................................................................................................71
References ..............................................................................................................74
apter 4: Bipolar Transistor Models ..........................................................75
A Little Bit of History ............................................................................................75
Basic NPN Transistor .............................................................................................76
Transistor Models in Different Operating Regions ................................................79
Low-Frequency Incremental Bipolar Transistor Model .........................................82
High-Frequency Incremental Model ......................................................................85
Reading a Transistor Datasheet ..............................................................................88
Limitations of Hybrid-Pi Model ............................................................................93
Chapter 4 Problems ................................................................................................94
References ..............................................................................................................95
apter 5: Basic Bipolar Transistor Ampli? ers and Biasing .......................97
The Issue of Transistor Biasing..............................................................................97
Some Transistor Ampli? ers..................................................................................101
Chapter 5 Problems ..............................................................................................121
References ............................................................................................................125
apter 6: Bandwidth Estimation Techniques and the
Method of Open-Circuit Time Constants .............................................127
Introduction to Open-Circuit Time Constants......................................................127
Transistor Ampli? er Examples ............................................................................132
Chapter 6 Problems ..............................................................................................156
References ............................................................................................................159
apter 7: Advanced Transistor Ampli? er Techniques ............................161
Worst-Case Open-Circuit Time Constant Calculations .......................................161
High-Frequency Output and Input Impedance of Emitter-Follower Buffers .......168
Bootstrapping .......................................................................................................177
Short-Circuit Time Constants ..............................................................................184
viii
Pole Splitting ........................................................................................................196
Chapter 7 Problems ..............................................................................................202
References ............................................................................................................205
Chapter 8: High-Gain Bipolar Ampli? ers and BJT Current Mirrors  ........207
The Need to Augment the Hybrid-Pi Model ........................................................207
Base-Width Modulation .......................................................................................209
Finding Parameters from a Transistor Datasheet .................................................211
Common-Emitter Ampli? er with Current Source Load ......................................212
Building Blocks ...................................................................................................213
Chapter 8 Problems ..............................................................................................238
References ............................................................................................................240
Chapter 9: Introduction to MOSFET Devices and
Basic MOS Ampli? ers ............................................................................241
Some Early History of Field-Effect Transistors ...................................................241
Qualitative Discussion of Basic MOS Devices ....................................................242
Figuring Out the V/I Curve of a MOS Device .....................................................243
MOS Small-Signal Model (Low Frequency) .......................................................246
MOS Small-Signal Model (High Frequency) ......................................................247
Basic MOS Ampli? ers .........................................................................................248
Chapter 9 Problems ..............................................................................................266
References ............................................................................................................268
Chapter 10: Bipolar Transistor Switching and the
Charge Control Model ...........................................................................269
Introduction ..........................................................................................................269
Development of the Switching Models ................................................................269
Reverse-Active Region ........................................................................................271
Saturation .............................................................................................................272
Junction Capacitances ..........................................................................................274
Relationship Between Charge Control and Hybrid-Pi Parameters ......................274
Finding Junction Capacitances from the Datasheet .............................................275
Manufacturers!ˉ Testing  ........................................................................................27
Charge Control Model Examples .........................................................................277
Emitter Switching ................................................................................................292
2N2222 Datasheet Excerpts
.......................................................................................294
Chapter 10 Problems ............................................................................................298
References ............................................................................................................303
hapter 11: Review of Feedback Systems .................................................305
Introduction and Some Early History of Feedback Control ................................305
Invention of the Negative Feedback Ampli? er ....................................................306
Control System Basics .........................................................................................308
Loop Transmission and Disturbance Rejection ...................................................309
Stability ................................................................................................................310
Routh Stability Criterion ......................................................................................311
The Phase Margin and Gain Margin Tests ...........................................................314
Relationship Between Damping Ratio and Phase Margin ...................................315
Loop Compensation Techniques!aLead and Lag Networks ...............................31
Parenthetical Comment on Some Interesting Feedback Loops ...........................317
Appendix: MATLAB Scripts ...............................................................................338
Chapter 11 Problems ............................................................................................342
References ............................................................................................................345
Chapter 12: Basic Operational Ampli? er Topologies
and a Case Study ...................................................................................347
Basic Device Operation .......................................................................................347
Brief Review of LM741 Op-Amp Schematic ......................................................358
Some Real-World Limitations of Operational Ampli? ers ...................................359
Chapter 12 Problems ............................................................................................366
References ............................................................................................................367
Chapter 13: Review of Current Feedback Operational Ampli? ers ..........369
Conventional Voltage-Feedback Op-Amp and the
Constant !°Gain BandwidthProduct!±Paradigm ...............................................369
Slew Rate Limitations in Conventional Op-Amps ...............................................371
Basic Current Feedback Op-Amp ........................................................................372
Absence of Slew Rate Limit in Current Feedback Op-Amps ..............................375
Manufacturer!ˉs Datasheet Information for a Current Feedback Ampli er ..........379
A More Detailed Model and Some Comments on Current-Feedback
Op-Amp Limitations ........................................................................................381
Chapter 13 Problems ............................................................................................382
References ............................................................................................................383
hapter 14: Analog Low-Pass Filters .........................................................385
Introduction ..........................................................................................................385
Review of Low-Pass Filter Basics .......................................................................386
Butterworth Filter .................................................................................................387
Chebyshev Filter ..................................................................................................390
Thompson Book.indb   x 3/20/2006   11:33:33 AM
Contents
Bessel Filter .........................................................................................................395
Comparison of Responses of Different Filter Types ............................................398
Filter Implementation ...........................................................................................400
Chapter 14 Problems ............................................................................................414
References ............................................................................................................416
Chapter 15: Review of Passive Components and a
Case Study in PC Board Layout .............................................................417
Resistors ...............................................................................................................417
Comments on Surface-Mount Resistors ..............................................................419
Comments on Resistor Types ...............................................................................420
Capacitors ............................................................................................................421
Inductors ..............................................................................................................424
Discussion of Printed-Circuit Board Layout Issues .............................................425
Approximate Inductance of a PC Board Trace Above a Ground Plane ...............428
Chapter 15 Problems ............................................................................................436
References ............................................................................................................437
Chapter 16: Other Useful Design Techniques and Loose Ends ................439
Thermal Circuits ..................................................................................................439
Steady-State Model of Conductive Heat Transfer ...............................................440
Thermal Energy Storage ......................................................................................441
Using Thermal Circuit Analogies to Determine Static Semiconductor
Junction Temperature .......................................................................................444
Mechanical Circuit Analogies ..............................................................................444
The Translinear Principle .....................................................................................449
Input Impedance of In? nitely Long Resistive Ladder .........................................451
Transmission Lines 101 .......................................................................................451
Node Equations and Cramer!ˉs Rule .....................................................................45
Finding Oscillation Modes ...................................................................................458
Some Comments on Scaling Laws in Nature ......................................................463
Chapter 16 Problems ............................................................................................469
References ............................................................................................................472
 楼主| 发表于 2008-8-3 11:37:31 | 显示全部楼层
partA
a2d90bd0-5f70-4ff7-8823-4ab286f5678f_A.rar
4.17 MB, 下载次数: 1306 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-8-3 11:40:25 | 显示全部楼层
partB
a2d90bd0-5f70-4ff7-8823-4ab286f5678f_B.rar
3.01 MB, 下载次数: 755 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-8-6 07:28:26 | 显示全部楼层
thanks!
发表于 2008-8-8 00:01:27 | 显示全部楼层
:victory:
发表于 2008-8-8 08:05:56 | 显示全部楼层
Thank you very much!!
发表于 2008-8-8 10:26:06 | 显示全部楼层
书是不错,但已经发过了。
发表于 2008-8-9 00:29:55 | 显示全部楼层
thanks
发表于 2008-8-20 16:00:29 | 显示全部楼层
Thanks a lot!
发表于 2008-8-20 22:21:39 | 显示全部楼层
感谢了,从新学习模拟电路
GMT+8, 2025-11-4 00:55 , Processed in 0.055558 second(s), 6 queries , Gzip On, Redis On.
