查看: 2894|回复: 8
[求助] vcs dumping problem, ./simv, please help
发表于 2017-8-25 05:09:22 | 显示全部楼层 |阅读模式
With help of folks in forum, I could run vcs:
vcs -Mupdate counter_4bit.v tb_counter_4bit.v -debug_all -full64 &
but after the run, when I run ./simv , I need help to handle "Dumping VCS annotated
I got the following dump:
Command line: ./simv
--- Stack trace follows:
Chronologic VCS simulator copyright 1991-2016
Contains Synopsys proprietary information.
Compiler version L-2016.06_Full64; Runtime version L-2016.06_Full64; Aug 20 08:49 2017
Dumping VCS Annotated Stack:
#0 0x00007f341695b197 in waitpid () from /lib64/libc.so.6
#1 0x00007f34168cd947 in do_system () from /lib64/libc.so.6
#2 0x00007f341caea6f8 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015 b313e639d2928478c79b3f673f99203bcf8be6460061210008 2236bffb2007f1e0ef9 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/liberrorinf.so
#3 0x00007f341caebde5 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015 b313efba706aab251478fa49e66610e453774633a6c152e7ef 778f2202cda681f3d4e () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/liberrorinf.so
#4 0x00007f341cae4f15 in SNPSle_d35ca1ff70d465c2b9b1a72eee90a506fdd009d3de3 db1de () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/liberrorinf.so
#5 0x00007f341a2b2088 in SNPSle_64133461705005bb725549e2e6fa1b3f () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#6 0x00007f341a15b266 in SNPSle_82244d58c54c18c70d63edc9becab634 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#8 0x00007f341c89f202 in mem_page_get_descr () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libsnpsmalloc.so
#9 0x00007f341c8a7a2e in mem_free () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libsnpsmalloc.so
#10 0x00007f341c892944 in snpsCheckFreeFunc () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libsnpsmalloc.so
#11 0x00007f3419fc1727 in SNPSle_77e776236473f4bc83d28b2811172395 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#12 0x00007f3419fbc55f in SNPSle_4e2b4bf1677349c165275718f4085a72 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#13 0x00007f3419e32cc1 in SNPSle_e08561af70b15158c1effee38014f2e6 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#14 0x00007f3419e32dce in SNPSle_6a600e65c1e59889d2167a3056e08869 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#15 0x00007f3419e32e24 in SNPSle_79019f86c02f3a7a4fc861b56b22e07a449f142e33a 64a009cd88060dca82713b97bc310751f5b0c () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#16 0x00007f34172fd36d in start_thread () from /lib64/libpthread.so.0
#17 0x00007f3416997b8f in clone () from /lib64/libc.so.6
#0 0x00007f341695b40d in nanosleep () from /lib64/libc.so.6
#1 0x00007f341695b34a in sleep () from /lib64/libc.so.6
#2 0x00007f3419d7f83e in SNPSle_95ae9cc2e78cc668673c60b8d88c4908 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#3 0x00007f3419d7f9c9 in SNPSle_92de4d0d4cf0d6931bc37e8d42a01d93 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#4 0x00007f3419d7e22a in SNPSle_b76ef993ee82b3d58a5cadddbec8b67c () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#5 0x00007f3419d7e4d6 in SNPSle_f28f24b8c84ac8f6e02e0b03bcd33aa8 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#6 0x00007f3419d479e6 in SNPSle_b02289328df49303de0a4a986839ba718c1b162de58 5ec41 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#7 0x00007f3419d4833f in SNPSle_b02289328df493035a8cfe7a2a96e3f1 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#8 0x00007f3419d49fe0 in SNPSle_7309f02bf869c35a32837a6e487da0db () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#9 0x00007f3419d4aadb in SNPSle_b02289328df493035a8cfe7a2a96e3f14356a2494eb 82428 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#10 0x00007f3419d4bf1e in SNPSle_b02289328df493035a8cfe7a2a96e3f105a2510afcb 822b0f2351f16fde66779 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#11 0x00007f3419d4c7ac in SNPSle_ba11b1edbd04051f5bb81b1861cdf84a () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#12 0x00007f3419d3abc4 in SNPSle_2e65c0794628fc5af60953149776c29b () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#13 0x00007f3419d321a3 in SNPSle_541f757be362289a7c9e5618c0ff28327846f8d3cc0 2839f () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#14 0x00007f3419d2cd5c in SNPSle_c0de1345d5ab80930e06dd2b68f214c3 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#15 0x00007f3419d2ce6d in SNPSle_25cd5712eacded5feaee03dc3430943e () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#16 0x00007f341a2ca487 in SNPSle_490598bfebcc8e8183ad3550288b1f82 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#17 0x00007f341a2d5553 in SNPSle_490598bfebcc8e81 () from /home/tools/synopsys/vcs-mx_vL-2016.06/linux64/lib/libvcsnew.so
#18 0x00007f341d5d62ab in main () from /home/dubeeloo/proj/RTLdesign/VCStraining/vcsfiles/simv.daidir/_csrc0.so
#19 0x00007f34168a74da in __libc_start_main () from /lib64/libc.so.6
#20 0x000000000040c27a in _start ()
No context available
发表于 2017-8-25 13:40:06 | 显示全部楼层
You can run Strace to trace the routine and check the processing
 楼主| 发表于 2017-8-26 02:05:00 | 显示全部楼层
回复 2# phoenixson
   thank you for the replyI will try it out
发表于 2017-8-26 11:05:45 | 显示全部楼层
seems you have not clean the history file, which run with version vcs-mx_vL-2016.06
 楼主| 发表于 2017-8-26 13:53:55 | 显示全部楼层
回复 4# meiming
   Thank you, meiming, for the reply
does the history matter for simv run?
how do I fix it. I did not find history file though
发表于 2017-9-11 15:11:19 | 显示全部楼层
If you are not authorised, change the vcs version. v201403 v201509 is ok. v201412 has the same error.
If you system is ubuntu, change the file maybe useful.
sudo gvim /etc/sysctl.d/10-ptrace.conf
        kernel.yama.ptrace_scope=0
CentOS & RHL have no solution.
 楼主| 发表于 2017-9-12 00:01:18 | 显示全部楼层
回复 6# johnli330
Thank you, johnli330, for the reply
my vcs version: Version L-2016.06
running on fedora 26 machine.
In your reply, you mentioned
V201403 v201509 is OK
did you mean ONLY   v201509 is OK?
where do I find the specified vcs installation?
发表于 2017-9-22 17:02:41 | 显示全部楼层
回复 7# xiaoyisimonguo
use http://www.daimugua.com/ to serach vcs resource. key word: synopsys or vcs or IC or eda .
发表于 2017-9-22 17:10:59 | 显示全部楼层
GMT+8, 2025-9-13 19:46 , Processed in 0.020731 second(s), 3 queries , Gzip On, Redis On.
