楼主 |
发表于 2016-7-26 11:44:57
显示全部楼层
回复 6# damonzhao
我用v2lvs把Verilog网表转换成了spi格式的网表。但是整个top的LVS还是有问题。
于是我就把rtl代码中的一个很小的子模块单独重新跑了一遍dc、icc、lvs。
发现这个子模块lvs能过。
top和子模块走的流程是一样的,但是top的lvs就过不了。
这是报告:
# # INCORRECT #
Error: Different numbers of nets (see below).
Error: Different numbers of instances (see below).
Error: Connectivity errors.
Error: Property errors.
Warning: Unbalanced smashed mosfets were matched.
Warning: Ambiguity points were found and resolved arbitrarily.
LAYOUT CELL NAME: top_uart_linear
SOURCE CELL NAME: top_uart_linear
INITIAL NUMBERS OF OBJECTS
Layout Source Component Type
Ports: 36 37 *
Nets: 9713 9539 *
Instances: 10112 10115 * MN (4 pins)
10124 10124 MP (4 pins)
1 1 D (2 pins)
Total Inst: 20237 20240
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports: 36 36
Nets: 5534 5320 *
Instances: 1120 1120 MN (4 pins)
1121 1117 * MP (4 pins)
1 1 D (2 pins)
2 2 AOI_3_1 (5 pins)
6 6 OAI_3_1 (5 pins)
3 3 SDW3 (4 pins)
9 9 SUP3 (4 pins)
43 43 SPDW_2_1 (4 pins)
3 3 SPDW_2_1_1 (5 pins)
5 5 SPDW_2_2 (5 pins)
59 59 SPDW_2_2_1 (6 pins)
6 6 SPDW_2_2_2 (7 pins)
3 3 SPDW_3_2 (6 pins)
186 187 * SPUP_2_1 (4 pins)
113 112 * SPUP_2_2 (5 pins)
81 81 SPUP_2_2_1 (6 pins)
17 17 SPUP_2_2_2 (7 pins)
3 3 SPUP_3_2 (6 pins)
71 71 SMN2 (4 pins)
71 71 SMP2 (4 pins)
1 1 SPMN((2+2)*1*1) (8 pins)
1 1 SPMP((2+2+1)*1) (8 pins)
3192 3198 * _invv (4 pins)
173 170 * _invx2v (4 pins)
1 1 _invx3v (4 pins)
435 435 _nand2v (5 pins)
16 16 _nand3v (6 pins)
11 11 _nand4v (7 pins)
60 60 _nor2v (5 pins)
9 9 _nor3v (6 pins)
8 8 _nor4v (7 pins)
3 3 _pdw2v (4 pins)
3 5 * _pup2v (4 pins)
1072 1072 _sdw2v (4 pins)
175 175 _smn3v (5 pins)
820 820 _sup2v (4 pins)
123 123 _tgmb (7 pins)
80 80 _xr2v (5 pins)
19 19 _xra2v (5 pins)
Total Inst: 9125 9126
* = Number of objects in layout different from number in source.
INCORRECT OBJECTS
LEGEND:
ne = Naming Error (same layout name found in source
circuit, but object was matched otherwise).
INCORRECT NETS
DISC# LAYOUT NAME SOURCE NAME
1 Net 1049 Xuu1/Xuu1/n68
** missing connection ** (SPDW_2_2_2):input
Xuu1/Xuu1/XU250/MI16:g
** missing connection ** (_sup2v):in2
Xuu1/Xuu1/XU250/MI9:g
** missing connection ** (_invv) ut
Xuu1/Xuu1/XU249/M_u3-M_u2:d
Xuu1/Xuu1/XU249/M_u3-M_u3:d
2 Net 1405 Xuu1/Xuu2/N92
(SPDW_2_2_2):input ** missing connection **
X1471/M1(64.270,50.315):g
Xuu1/Xuu2/XU66/MI14:g
** missing connection ** (_invv):in
Xuu1/Xuu2/Xsub_61/XU6/MU1-M_u2:g
Xuu1/Xuu2/Xsub_61/XU6/MU1-M_u3:g
Xuu1/Xuu2/Xadd_59/XU1_2/MU3-M_u2:g
Xuu1/Xuu2/Xadd_59/XU1_2/MU3-M_u3:g
Xuu1/Xuu2/Xadd_57/XU1_1_3/MU4-M_u2:d
Xuu1/Xuu2/Xadd_57/XU1_1_3/MU4-M_u3:d
** missing connection ** (_tgmb):sel1
Xuu1/Xuu2/Xadd_59/XU1_2/MI14-M_u3:g
Xuu1/Xuu2/Xadd_59/XU1_2/MI13-M_u2:g
3 Net 1591 Xuu1/Xuu2/n280
X1471/M5(65.310,50.315):g
Xuu1/Xuu2/XU66/MI15:g
4 Net 376 Xuu1/Xuu2/N222
Xuu1/Xuu2/XU67/MU1-M_u2:g
Xuu1/Xuu2/XU67/MU1-M_u3:g
Xuu1/Xuu2/Xadd_78_aco/XU19/M_u4-M_u2:d
Xuu1/Xuu2/Xadd_78_aco/XU19/M_u4-M_u3:d
5 Net 1240 Xuu1/Xuu2/N41
X452/M5(52.960,78.145):g ** missing connection **
** missing connection ** (SPUP_2_2):input
Xuu1/Xuu2/XU124/MI20:g
** missing connection ** (_pup2v):in2
Xuu1/Xuu2/XU271/M_u9:g
** missing connection ** (_invv):out
Xuu1/Xuu2/Xsub_45/XU2_5/MU18-M_u2:d
Xuu1/Xuu2/Xsub_45/XU2_5/MU18-M_u3:d
** missing connection ** (_sdw2v):in1
Xuu1/Xuu2/XU124/MI24:g
6 Net 1454 Xuu1/Xuu2/n134
(SPUP_2_2):input ** missing connection **
X601/M7(71.235,69.825):g
(_sdw2v):in1 ** missing connection **
X601/M3(71.110,68.865):g
** missing connection ** (SPUP_2_1):input
Xuu1/Xuu2/XU213/MI19:g
Xuu1/Xuu2/XU211/MI21:g
** missing connection ** (_sdw2v):in2
Xuu1/Xuu2/XU213/MI23:g
Xuu1/Xuu2/XU211/MI16:g
Xuu1/Xuu2/Xadd_68_U1_1_3/MU4-M_u2:d
Xuu1/Xuu2/Xadd_68_U1_1_3/MU4-M_u3:d
7 Net 1467 Xuu1/Xuu2/n135
X601/M5(71.770,69.825):g
(_sdw2v):in2 ** missing connection **
X601/M0(71.770,68.865):g
Xuu1/Xuu2/XU213/M_u2:g
Xuu1/Xuu2/XU213/MI16:g
Xuu1/Xuu2/XU213/MI22:g
Xuu1/Xuu2/Xadd_68_U1_1_4/MU4-M_u2:d
Xuu1/Xuu2/Xadd_68_U1_1_4/MU4-M_u3:d
8 Net 556 Xuu1/Xuu1/N72
X1473/M1(29.945,86.315):g
Xuu1/Xuu1/XU130/MI21:g
Xuu1/Xuu1/XU250/MI17:g
Xuu1/Xuu1/Xsub_95/XU2_2/MU18-M_u2:d
Xuu1/Xuu1/Xsub_95/XU2_2/MU18-M_u3:d
Xuu1/Xuu1/XU130/MI16:g
9 Net 1404 Xuu1/Xuu2/N214
Xuu1/Xuu2/Xcycle_reg_3_/MI5:g
Xuu1/Xuu2/Xcycle_reg_3_/MI6:g
Xuu1/Xuu2/XU146/M_u3-M_u2:d
Xuu1/Xuu2/XU146/M_u3-M_u3:d
10 Net 1466 Xuu1/Xuu2/N215
Xuu1/Xuu2/Xcycle_reg_2_/MI5:g
Xuu1/Xuu2/Xcycle_reg_2_/MI6:g
Xuu1/Xuu2/XU147/M_u3-M_u2:d
Xuu1/Xuu2/XU147/M_u3-M_u3:d
11 Net 1109 Xuu1/Xuu2/N91
X1471/M2(64.530,50.315):g
Xuu1/Xuu2/XU66/MI16:g
Xuu1/Xuu2/Xadd_57/XU1_1_2/MU4-M_u2:d
Xuu1/Xuu2/Xadd_57/XU1_1_2/MU4-M_u3:d
Xuu1/Xuu2/Xsub_61/XU4/MU1-M_u2:g
Xuu1/Xuu2/Xsub_61/XU4/MU1-M_u3:g
Xuu1/Xuu2/Xadd_59/XU1_1/MU3-M_u2:g
Xuu1/Xuu2/Xadd_59/XU1_1/MU3-M_u3:g
Xuu1/Xuu2/Xadd_59/XU1_1/MI14-M_u3:g
Xuu1/Xuu2/Xadd_59/XU1_1/MI13-M_u2:g
12 Net 1312 Xuu1/Xuu2/n129
Xuu1/Xuu2/XU213/MI20:g
Xuu1/Xuu2/XU264/M_u4-M_u2:d
Xuu1/Xuu2/XU264/M_u4-M_u3:d
Xuu1/Xuu2/XU213/MI24:g
13 Net 1246 Xuu1/Xuu1/N196
X709/M7(54.450,15.605):d ** missing connection **
** missing connection ** (SPDW_2_1):output
Xuu1/Xuu1/XU244/M_u2:d
Xuu1/Xuu1/XU244/M_u3:d
** missing connection ** (_pup2v):out1
Xuu1/Xuu1/XU244/M_u9:d
Xuu1/Xuu1/XU161/MI2:d
Xuu1/Xuu1/Xcycle_reg_2_/MI135:g
Xuu1/Xuu1/Xcycle_reg_2_/MI139:g
** missing connection ** (_sup2v):out1
Xuu1/Xuu1/XU244/MI16-MI12:s
14 Net 79 Xuu1/Xuu2/N102
X1436/M5(60.570,52.945):g ** missing connection **
** missing connection ** (SPUP_2_2_2):input
Xuu1/Xuu2/XU52/MI10:g
** missing connection ** (_pup2v):in1
Xuu1/Xuu2/XU82/MU24:g
Xuu1/Xuu2/XU52/MI13-M_u10:g
Xuu1/Xuu2/Xadd_59/XU1_4/MU18-M_u2:d
Xuu1/Xuu2/Xadd_59/XU1_4/MU18-M_u3:d
15 Net 146 Xuu2/Xuu1/N10
Xuu2/Xuu1/Xadd_46/XU1_1_5/MU4-M_u2:d
Xuu2/Xuu1/Xadd_46/XU1_1_5/MU4-M_u3:d
** missing connection ** (_nand2v):in1
Xuu2/Xuu1/XU21/M_u2-M_u1:g
Xuu2/Xuu1/XU21/M_u2-M_u3:g
16 Net 147 Xuu2/Xuu1/N21
(_invv):out ** missing connection **
X1378/M2(15.730,14.315):d
X1378/M5(15.730,13.470):d
** missing connection ** (_nor4v):in4
Xuu2/Xuu1/XU28/MU8-M_u8:g
Xuu2/Xuu1/XU28/MU8-M_u7:g
Xuu2/Xuu1/XU29/M_u4-M_u2:d
Xuu2/Xuu1/XU29/M_u4-M_u3:d
Xuu2/Xuu1/XU19/M_u3-M_u2:d
Xuu2/Xuu1/XU19/M_u3-M_u3:d
17 Net 172 Xuu2/Xuu1/N6
Xuu2/Xuu1/Xadd_46/XU1_1_1/MU4-M_u2:d
Xuu2/Xuu1/Xadd_46/XU1_1_1/MU4-M_u3:d
Xuu2/Xuu1/XU25/M_u2-M_u1:g
Xuu2/Xuu1/XU25/M_u2-M_u3:g
18 Net 264 Xuu2/Xuu1/N7
Xuu2/Xuu1/Xadd_46/XU1_1_2/MU4-M_u2:d
Xuu2/Xuu1/Xadd_46/XU1_1_2/MU4-M_u3:d
Xuu2/Xuu1/XU24/M_u2-M_u1:g
Xuu2/Xuu1/XU24/M_u2-M_u3:g
19 Net 326 Xuu2/Xuu1/N20
X1379/M2(18.070,11.285):d
X1379/M5(18.070,12.130):d
** missing connection ** (_nand4v):in1
Xuu2/Xuu1/XU27/MI9:g
Xuu2/Xuu1/XU27/MI19:g
Xuu2/Xuu1/XU20/M_u3-M_u2:d
Xuu2/Xuu1/XU20/M_u3-M_u3:d
** missing connection ** (_nor4v):out
Xuu2/Xuu1/XU28/MU8-M_u8:d
Xuu2/Xuu1/XU28/MU8-M_u5:d
Xuu2/Xuu1/XU28/MU8-M_u3:d
Xuu2/Xuu1/XU28/MU8-M_u4:d
Xuu2/Xuu1/XU28/MU8-M_u7:s
20 Net 367 Xuu2/Xuu1/N19
X1380/M2(20.130,17.915):d
X1380/M5(20.130,17.070):d
** missing connection ** (_nand4v):in4
Xuu2/Xuu1/XU27/MI14:g
Xuu2/Xuu1/XU27/MI18:g
Xuu2/Xuu1/XU31/M_u4-M_u2:d
Xuu2/Xuu1/XU31/M_u4-M_u3:d
Xuu2/Xuu1/XU21/M_u3-M_u2:d
Xuu2/Xuu1/XU21/M_u3-M_u3:d
21 Net 393 Xuu2/Xuu1/N8
Xuu2/Xuu1/Xadd_46/XU1_1_3/MU4-M_u2:d
Xuu2/Xuu1/Xadd_46/XU1_1_3/MU4-M_u3:d
Xuu2/Xuu1/XU23/M_u2-M_u1:g
Xuu2/Xuu1/XU23/M_u2-M_u3:g
22 Net 463 Xuu2/Xuu1/N17
X1385/M2(24.530,14.315):d
X1385/M5(24.530,13.470):d
** missing connection ** (_nand4v):in2
Xuu2/Xuu1/XU27/MI16:g
Xuu2/Xuu1/XU27/MU53:g
Xuu2/Xuu1/XU33/M_u4-M_u2:d
Xuu2/Xuu1/XU33/M_u4-M_u3:d
Xuu2/Xuu1/XU23/M_u3-M_u2:d
Xuu2/Xuu1/XU23/M_u3-M_u3:d
23 Net 496 Xuu2/Xuu1/N11
Xuu2/Xuu1/Xadd_46/XU1_1_6/MU4-M_u2:d
Xuu2/Xuu1/Xadd_46/XU1_1_6/MU4-M_u3:d
Xuu2/Xuu1/XU20/M_u2-M_u1:g
Xuu2/Xuu1/XU20/M_u2-M_u3:g
24 Net 636 Xuu2/Xuu1/N14
X1387/M2(31.670,17.915):d
X1387/M5(31.670,17.070):d
Xuu2/Xuu1/XU13/MU8-M_u8:g
Xuu2/Xuu1/XU13/MU8-M_u7:g
Xuu2/Xuu1/XU26/M_u3-M_u2:d
Xuu2/Xuu1/XU26/M_u3-M_u3:d
Xuu2/Xuu1/XU14/M_u4-M_u2:d
Xuu2/Xuu1/XU14/M_u4-M_u3:d
25 Net 534 Xuu2/Xuu1/N12
Xuu2/Xuu1/Xadd_46/XU1_1_7/MU4-M_u2:d
Xuu2/Xuu1/Xadd_46/XU1_1_7/MU4-M_u3:d
Xuu2/Xuu1/XU19/M_u2-M_u1:g
Xuu2/Xuu1/XU19/M_u2-M_u3:g
26 Net 644 Xuu2/Xuu1/N16
X1391/M2(35.330,14.885):d
X1391/M5(35.330,15.730):d
Xuu2/Xuu1/XU24/M_u3-M_u2:d
Xuu2/Xuu1/XU24/M_u3-M_u3:d
** missing connection ** (_nand4v):out
Xuu2/Xuu1/XU27/MI14:d
Xuu2/Xuu1/XU27/MI15:d
Xuu2/Xuu1/XU27/MI16:d
Xuu2/Xuu1/XU27/MI9:d
Xuu2/Xuu1/XU27/MI18:s
** missing connection ** (_nand2v):in2
Xuu2/Xuu1/XU5/M_u2-M_u2:g
Xuu2/Xuu1/XU5/M_u2-M_u4:g
27 Net 1308 Xuu1/Xuu2/N183
Xuu1/Xuu2/XU272/M_u4-M_u2:d
Xuu1/Xuu2/XU272/M_u4-M_u3:d
** missing connection ** (_nand3v):in2
Xuu1/Xuu2/XU146/M_u4-M_u1:g
Xuu1/Xuu2/XU146/M_u4-M_u4:g
28 Net 1420 Xuu1/Xuu2/N182
X1436/M5(60.570,52.945):d ** missing connection **
Xuu1/Xuu2/XU271/M_u2:d
Xuu1/Xuu2/XU271/M_u3:d
Xuu1/Xuu2/XU271/M_u9:d
Xuu1/Xuu2/XU82/MU24:d
Xuu1/Xuu2/XU271/MI16-MI12:s
Xuu1/Xuu2/XU147/M_u4-M_u1:g
Xuu1/Xuu2/XU147/M_u4-M_u4:g
29 Net 584 Xuu1/Xuu1/N121
X1473/M4(30.990,86.315):g
** missing connection ** (SPUP_2_2_1):input
Xuu1/Xuu1/XU153/MI7:g
Xuu1/Xuu1/XU250/MI14:g
Xuu1/Xuu1/XU153/MI17-M_u10:g
Xuu1/Xuu1/Xsub_105/XU2_10/MU18-M_u2:d
Xuu1/Xuu1/Xsub_105/XU2_10/MU18-M_u3:d
30 Net 590 Xuu1/Tc[3]
X1473/M5(31.250,86.315):g
Xuu1/Xuu1/XU250/MU25:g
31 Net 357 Xuu1/Tc[2]
X1473/M3(30.515,86.315):g
(_sup2v):in2 ** missing connection **
X1473/M10(30.425,85.345):g
Xuu1/Xuu1/XU250/MI15:g
** missing connection ** (_sup2v):in1
Xuu1/Xuu1/XU250/MI11:g
32 Net 1554 Xuu1/Xuu2/n242
X1471/M3(64.770,50.075):g
(_sup2v):in1 ** missing connection **
X1471/M10(65.015,49.345):g
Xuu1/Xuu2/XU66/MI18:g
Xuu1/Xuu2/XU66/MI12:g
33 Net 582 Xuu1/Xuu1/N118
X1473/M0(29.635,86.315):g
Xuu1/Xuu1/XU162/MI7:g
Xuu1/Xuu1/XU250/MI18:g
Xuu1/Xuu1/XU162/MI17-M_u10:g
Xuu1/Xuu1/Xsub_105/XU2_7/MU18-M_u2:d
Xuu1/Xuu1/Xsub_105/XU2_7/MU18-M_u3:d
34 Net 1541 Xuu1/Xuu2/N18
X1471/M0(64.030,50.315):g
Xuu1/Xuu2/XU44/MI12:g
Xuu1/Xuu2/XU66/MU25:g
Xuu1/Xuu2/XU44/MI6-M_u10:g
Xuu1/Xuu2/Xsub_42/XU21/M_u4-M_u2:d
Xuu1/Xuu2/Xsub_42/XU21/M_u4-M_u3:d
35 Net 1452 Xuu1/Xuu2/n174
(SPDW_2_2_2):output ** missing connection **
X1471/M3(64.770,50.075):d
X1471/M4(65.030,50.075):s
(_sup2v):out1 ** missing connection **
X1471/M11(65.275,49.345):s
** missing connection ** (SPDW_2_2_2):output
Xuu1/Xuu2/XU66/MI18:d
Xuu1/Xuu2/XU66/MI17:d
Xuu1/Xuu2/XU66/MI13:s
36 Net 310 Xuu2/Xuu1/N5
Xuu2/Xuu1/XU26/M_u2-M_u1:g
Xuu2/Xuu1/XU26/M_u2-M_u3:g
Xuu2/Xuu1/Xadd_46/XU1/MU1-M_u2:d
Xuu2/Xuu1/Xadd_46/XU1/MU1-M_u3:d
37 Net 389 Xuu2/Xuu1/N15
Xuu2/Xuu1/XU25/M_u3-M_u2:d
Xuu2/Xuu1/XU25/M_u3-M_u3:d
Xuu2/Xuu1/Xcounter_reg_1_/MI5:g
Xuu2/Xuu1/Xcounter_reg_1_/MI6:g
38 Net X1386/6 Xuu1/Xuu1/XU249/net6
(_invv):in ** missing connection **
X1386/M2(29.070,86.885):g
X1386/M5(29.070,87.730):g
Xuu1/Xuu1/XU249/M_u3-M_u2:g
Xuu1/Xuu1/XU249/M_u3-M_u3:g
39 Net X1473/11 Xuu1/Xuu1/XU250/net36
X1473/M0(29.635,86.315):d
X1473/M1(29.945,86.315):s
X1473/M10(30.425,85.345):d
Xuu1/Xuu1/XU250/MI18:d
Xuu1/Xuu1/XU250/MI17:d
Xuu1/Xuu1/XU250/MI9:s
40 Net 1265 Xuu1/Xuu1/N198
1291
41 Net 1640 Xuu1/Xuu1/N174
1607
42 Net 1552 Xuu1/Xuu1/n153
1490
43 Net 1735 Xuu1/Xuu1/N173
96
44 Net 1676 Xuu1/Xuu1/N175
1456
45 Net 1515 Xuu1/Xuu1/N176
1402
46 Net 1511 Xuu1/Xuu1/N171
1651
47 Net 573 Xuu1/Xuu1/N91
1411
48 Net 1284 Xuu1/Xuu1/N111
1379
49 Net 716 Xuu1/Xuu1/N112
1482
50 Net 924 Xuu1/Xuu1/N113
1428
INCORRECT INSTANCES
51 X452/M5(52.960,78.145) MP(PCH) ** missing instance **
52 X453/M5(60.960,13.345) MP(PCH) ** missing instance **
53 X709/M7(54.450,15.605) MP(PCH) ** missing instance **
54 X1436/M5(60.570,52.945) MP(PCH) ** missing instance **
55 (_invx2v) ** missing injected instance **
Devices:
X641/M11(72.710,47.995) MP(PCH)
X641/M5(72.710,47.285) MN(NCH)
X426/M1(69.695,47.995) MP(PCH)
X426/M0(69.695,47.285) MN(NCH)
56 (_invx2v) ** missing injected instance **
Devices:
X613/M11(63.900,15.720) MP(PCH)
X613/M5(63.900,15.065) MN(NCH)
X1542/M19(69.485,11.995) MP(PCH)
X1542/M1(69.475,11.465) MN(NCH)
57 (_invx2v) ** missing injected instance **
Devices:
X1410/M7(57.100,13.420) MP(PCH)
X1410/M3(57.100,14.315) MN(NCH)
X1540/M19(51.315,11.995) MP(PCH)
X1540/M1(51.325,11.465) MN(NCH)
58 (SPUP_2_2) ** missing gate **
Transistors:
X601/M5(71.770,69.825) MP(PCH)
X601/M8(70.975,69.825) MP(PCH)
X601/M6(71.510,69.825) MP(PCH)
X601/M7(71.235,69.825) MP(PCH)
59 ** missing injected instance ** (_invv)
Devices:
Xuu1/Xuu1/XU242/MI8-M_u3 MP(PCH)
Xuu1/Xuu1/XU242/MI8-M_u2 MN(NCH)
60 ** missing injected instance ** (_invv)
Devices:
Xuu1/Xuu1/XU245/M_u4-M_u3 MP(PCH)
Xuu1/Xuu1/XU245/M_u4-M_u2 MN(NCH)
61 ** missing injected instance ** (_invv)
Devices:
Xuu1/Xuu2/Xadd_78_aco/XU19/M_u4-M_u3 MP(PCH)
Xuu1/Xuu2/Xadd_78_aco/XU19/M_u4-M_u2 MN(NCH)
62 ** missing injected instance ** (_invv)
Devices:
Xuu1/Xuu1/Xcycle_reg_1_/MI139 MP(PCH)
Xuu1/Xuu1/Xcycle_reg_1_/MI135 MN(NCH)
63 ** missing injected instance ** (_invv)
Devices:
Xuu1/Xuu1/Xcycle_reg_3_/MI139 MP(PCH)
Xuu1/Xuu1/Xcycle_reg_3_/MI135 MN(NCH)
64 ** missing injected instance ** (_invv)
Devices:
Xuu1/Xuu1/XU249/M_u3-M_u3 MP(PCH)
Xuu1/Xuu1/XU249/M_u3-M_u2 MN(NCH)
65 ** missing injected instance ** (_pup2v)
Devices:
Xuu1/Xuu2/XU82/MU24 MP(PCH)
Xuu1/Xuu2/XU271/M_u9 MP(PCH)
66 ** missing injected instance ** (_pup2v)
Devices:
Xuu1/Xuu1/XU161/MI2 MP(PCH)
Xuu1/Xuu1/XU244/M_u9 MP(PCH)
67 ** missing gate ** (SPUP_2_1)
Transistors:
Xuu1/Xuu2/XU213/MI20 MP(PCH)
Xuu1/Xuu2/XU213/MI19 MP(PCH)
Xuu1/Xuu2/XU213/M_u2 MP(PCH)
想问一下出了这样的问题如何debug,有什么常用的途径和方法吗? |
