查看: 7889|回复: 14
[求助] calibre lvs problem
发表于 2015-8-3 18:55:10 | 只看该作者 |倒序浏览 |阅读模式
在做lvs的时候,calibre会把并联或者串联的mos管合并。
怎么关闭这个功能?
2#
 楼主| 发表于 2015-8-3 19:00:09 | 只看该作者
如果把上下量两排管子交换calibre查不出来,郁闷
 楼主| 发表于 2015-8-3 19:01:11 | 只看该作者
回复 2# dtao
    VARIABLE POWER_NAME "?VDD?" "?vdd?"
VARIABLE GROUND_NAME "?VSS?" "?GND?" "?vss?" "?gnd?"
LVS POWER  NAME POWER_NAME
LVS GROUND NAME GROUND_NAME
LVS RECOGNIZE GATES                    NONE
VIRTUAL CONNECT COLON                  NO
LVS ABORT ON SOFTCHK                   NO
LAYOUT CASE                            YES
SOURCE CASE                            YES
LVS COMPARE CASE                       YES
LVS REPORT MAXIMUM                     50
LVS PROPERTY RESOLUTION MAXIMUM        32
LVS IGNORE PORTS                       NO
LVS CHECK PORT NAMES                   YES
LVS CELL SUPPLY                        NO
LVS IGNORE TRIVIAL NAMED PORTS         NO
LVS BUILTIN DEVICE PIN SWAP            YES
LVS ALL CAPACITOR PINS SWAPPABLE       NO
LVS DISCARD PINS BY DEVICE             NO
LVS SOFT SUBSTRATE PINS                NO
LVS INJECT LOGIC                       YES
LVS EXPAND UNBALANCED CELLS            YES
LVS EXPAND SEED PROMOTIONS             NO
LVS PRESERVE PARAMETERIZED CELLS       NO
LVS GLOBALS ARE PORTS                  YES
LVS REVERSE WL                         NO
LVS SPICE PREFER PINS                  NO
LVS SPICE SLASH IS SPACE               YES
LVS SPICE ALLOW FLOATING PINS          YES
LVS SPICE ALLOW UNQUOTED STRINGS       NO
LVS SPICE CONDITIONAL LDD              NO
LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
LVS SPICE IMPLIED MOS AREA             NO
LVS SPICE OVERRIDE GLOBALS             NO
LVS SPICE REDEFINE PARAM               NO
LVS REDUCE SPLIT GATES        NO               ///###change  add this for check same nodes missing net.20150624
LVS SPICE REPLICATE DEVICES   YES              ///###change  add this for check same nodes missing net.20150624
LVS REDUCE PARALLEL MOS                NO
LVS SPICE SCALE X PARAMETERS           NO
LVS SPICE STRICT WL                    NO
LVS STRICT SUBTYPES                    NO
LVS EXACT SUBTYPES                     NO
LVS DOWNCASE DEVICE                    NO
LVS REPORT OPTION                      A
//VIRTUAL CONNECT NAME "?VDD?" "?VSS?" "?GND?" "?vdd?" "?vss?" "?gnd?"
//LVS FILTER UNUSED OPTION             AB RC RE RG YC
 楼主| 发表于 2015-8-3 19:12:03 | 只看该作者
回复 2# dtao
    NNITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              5         5
Nets:               7         7
Instances:          4         4         M (4 pins)
Total Inst:         4         4
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              5         5
Nets:               5         5
Instances:          2         2         SM2 (4 pins)
Total Inst:         2         2
发表于 2015-8-3 19:48:18 | 只看该作者
LVS Reduce Parallel MOS    NO
LVS Reduce Series MOS     NO
LVS Reduce Split Gates   NO
这三个选项里的一个或多个,你试吧
 楼主| 发表于 2015-8-3 20:57:09 | 只看该作者
回复 5# bsbs525
LVS REDUCE SERIES MOS                NO
全改成no了,还是不行呢
 楼主| 发表于 2015-8-4 09:34:50 | 只看该作者
回复 6# dtao
    就是这种结构,做lvs的时候一下就被合并了。
而且我把下面这些参数都关了
发表于 2015-8-4 09:37:50 | 只看该作者
There is one more option:
LVS REDUCE SEMI SERIES MOS                NO
Good luck.
 楼主| 发表于 2015-8-4 10:22:04 | 只看该作者
回复 8# d09ee2612
也关掉了,我看到了一个奇特的现象我在我自己的rule file里定义:
但是calibre在做lvs调用我的rule file之前自己定义了一些参数:
把我自己定义的给覆盖了。
 楼主| 发表于 2015-8-4 10:42:15 | 只看该作者
回复 9# dtao
    我在这种gui模式下能把他预设的option覆盖掉吗?
比如这一句:
LVS RECOGNIZE GATES ALL
改成
GMT+8, 2025-9-16 07:03 , Processed in 0.017226 second(s), 3 queries , Gzip On, Redis On.
