查看: 2862|回复: 8
[求助] why apply these vias , encounter cause Metal drc problem
发表于 2015-6-2 10:32:50 | 显示全部楼层 |阅读模式
I am doing tsmc 16nm p&r , found that some strange metal2 space ERROR , cauased by via12_cut cell , why encounter dont choose other type viacut cell to avoid these drc problem ? any expert give me some suggestions ?
发表于 2015-6-2 13:30:42 | 显示全部楼层
太先进了,表示没有做过
发表于 2015-6-2 13:43:56 | 显示全部楼层
回复 1# paulsuzhou
sorry I use ICC not encounter, but I know in ICC there have command to avoid this problem.
set_route_zrt_common_options -connect_within_pins_by_layer_name {}
If you have ICC that you could reference this.
 楼主| 发表于 2015-6-2 15:30:54 | 显示全部楼层
回复 3# kevin9133023
    Thank you very much !  I use EDI , so
发表于 2015-6-3 10:24:08 | 显示全部楼层
看看setNanoRouteMode中-routeWithVIaInPin和-routeWithViaOnlyForStandardCellPin两个选项的不同设置是否能改变route结果
 楼主| 发表于 2015-6-3 19:25:23 | 显示全部楼层
回复 5# qingwatiaowu
    厉害,我去试试看
发表于 2015-6-16 09:40:31 | 显示全部楼层
苏州有做16nm的公司?
发表于 2015-6-16 10:06:55 | 显示全部楼层
zhongshenghongxin 吧, 目前最火爆的公司,
发表于 2018-10-11 09:51:35 | 显示全部楼层
回复 7# jingest
   有的,同时做7nm的
GMT+8, 2025-9-11 01:12 , Processed in 0.022695 second(s), 6 queries , Gzip On, Redis On.
