hi,大家好,小弟最近在仿真xilinx给的PIO的PCIE的例子,仿真一直卡在了wait(trn_link_up_n==0),也就是说链路不通,求各位大神指教啊。仿真工具是ISE14.1自带的isim,下面是仿真的时候一些warning。
ISim P.15xf (signature 0x2f00eba5)
This is a Full version of ISim.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 5 of formal port DFETAP1 is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 1 of formal port GREFCLKRX is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 1 of formal port GREFCLKTX is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 2 of formal port NORTHREFCLKRX is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 2 of formal port NORTHREFCLKTX is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 2 of formal port SOUTHREFCLKRX is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 2 of formal port SOUTHREFCLKTX is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 3 of formal port TXENPRBSTST is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 3 of formal port TXHEADER is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 5 of formal port TXPOSTEMPHASIS is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 1 of formal port TXPRBSFORCEERR is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 4 of formal port TXPREEMPHASIS is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 7 of formal port TXSEQUENCE is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 1 of formal port TXSTARTSEQ is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 1 of formal port USRCODEERR is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 1 of formal port IGNORESIGDET is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 1 of formal port PERFCLKRX is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 1 of formal port PERFCLKTX is not equal to width 32 of actual constant.
WARNING: For instance gtx_v6_i/\GTXD[0].GTX /, width 1 of formal port RXDLYALIGNRESET is not equal to width 32 of actual constant.
WARNING: File "D:/PCIE_TEST_3/pcie/pcie_2_0_v6.v" Line 630. For instance pcie_2_0_i/pcie_bram_i/, width 72 of formal port mim_tx_rdata is not equal to width 69 of actual signal MIMTXRDATA.
WARNING: File "D:/PCIE_TEST_3/pcie/pcie_2_0_v6.v" Line 629. For instance pcie_2_0_i/pcie_bram_i/, width 72 of formal port mim_rx_rdata is not equal to width 68 of actual signal MIMRXRDATA.
WARNING: File "D:/PCIE_TEST_3/pcie/ipcore_dir/v6_pcie_v1_7/example_design/EP_MEM.v" Line 925. For instance EP_MEM/ep_mem_erom/, width 4 of formal port DOPA is not equal to width 1 of actual signal DOPA.
WARNING: File "D:/PCIE_TEST_3/pcie/ipcore_dir/v6_pcie_v1_7/example_design/EP_MEM.v" Line 926. For instance EP_MEM/ep_mem_erom/, width 4 of formal port DOPB is not equal to width 1 of actual signal DOPB.
WARNING: File "D:/PCIE_TEST_3/pcie/pcie_2_0_rport_v6.v" Line 1744. For instance pcie_2_0_i/pcie_bram_i/, width 72 of formal port mim_tx_rdata is not equal to width 69 of actual signal MIMTXRDATA.
WARNING: File "D:/PCIE_TEST_3/pcie/pcie_2_0_rport_v6.v" Line 1743. For instance pcie_2_0_i/pcie_bram_i/, width 72 of formal port mim_rx_rdata is not equal to width 68 of actual signal MIMRXRDATA.
Time resolution is 1 ps
Simulator is doing circuit initialization process.
[ 0] board.EP.core.pcie_2_0_i.pcie_bram_i ROWS_TX 1 COLS_TX 4
[ 0] board.EP.core.pcie_2_0_i.pcie_bram_i ROWS_RX 1 COLS_RX 4
[ 0] board.EP.core.pcie_2_0_i.pcie_bram_i.pcie_brams_tx NUM_BRAMS 4 DOB_REG 1 WIDTH 18 RAM_WRITE_LATENCY 0 RAM_RADDR_LATENCY 0 RAM_RDATA_LATENCY 2
[ 0] board.EP.core.pcie_2_0_i.pcie_bram_i.pcie_brams_rx NUM_BRAMS 4 DOB_REG 1 WIDTH 18 RAM_WRITE_LATENCY 0 RAM_RADDR_LATENCY 0 RAM_RDATA_LATENCY 2
[ 0] board.RP.rport.pcie_2_0_i.pcie_bram_i ROWS_TX 1 COLS_TX 4
[ 0] board.RP.rport.pcie_2_0_i.pcie_bram_i ROWS_RX 1 COLS_RX 4
[ 0] board.RP.rport.pcie_2_0_i.pcie_bram_i.pcie_brams_tx NUM_BRAMS 4 DOB_REG 1 WIDTH 18 RAM_WRITE_LATENCY 0 RAM_RADDR_LATENCY 0 RAM_RDATA_LATENCY 2
[ 0] board.RP.rport.pcie_2_0_i.pcie_bram_i.pcie_brams_rx NUM_BRAMS 4 DOB_REG 1 WIDTH 18 RAM_WRITE_LATENCY 0 RAM_RADDR_LATENCY 0 RAM_RDATA_LATENCY 2
[ 0] : System Reset Asserted...
Finished circuit initialization process.
[ 500000] : test_start.....
ISim> run all
[ 4995000] : System Reset De-asserted...
[ 15917246] : Transaction Reset Is De-asserted...
Stopped at time : 176853150 ps : File "v:/hipsBuilds/P_hips_v05.0/rst/hips/gtxe1/B_GTXE1_enc.v" Line 33061 |
