查看: 3575|回复: 11
[求助] 偏执电流求解
发表于 2013-10-21 21:46:48 | 显示全部楼层 |阅读模式
电流镜偏置电路
电流镜偏置电路
图中电流镜偏置电路,不考虑体效应,问流过电阻R的电流是多少?大神稍微说明解释一下。
发表于 2013-10-22 09:05:18 | 显示全部楼层
when the circuit achieve stable state, the current passing the resistor R is 20uA.
at the initial state, Pmos mirror sources40uA, while the Nmos mirror can only sink 20uA, so there is a net sourcing 20uA current charging to the parasitic capacitors of P/Nmos drain region. finally, the voltage on the upper node of the resistor raises, and push the PMOS to the linear region a bit, and make the sourcing ability weaker till 20uA, and then the balance is achieved.
发表于 2013-10-22 09:23:56 | 显示全部楼层
回复 2# wfcawy
   “at the initial state, Pmos mirror sources40uA, while the Nmos mirror can only sink 20uA”    有什么根据吗
 楼主| 发表于 2013-10-22 09:39:56 | 显示全部楼层
回复 2# wfcawy
Thanks。。。。。。。。
发表于 2013-10-22 10:06:01 | 显示全部楼层
俺仿了一下,最右PMOS确实没出现40A的情况。
红线为最右NMOS漏电流,黄线为最右PMOS源电流。
发表于 2013-10-22 10:18:57 | 显示全部楼层
回复 1# 薛定谔的太极拳
没电源大小,没R大小,怎么求,最高20μA,也可能低于。
发表于 2013-10-22 11:02:58 | 显示全部楼层
it is an assumption, and it shows the conflict of the design.
A transient simulation can catch everything with the consideration of all the parasitic.
But the final conclusion will not change.
发表于 2013-10-22 13:17:50 | 显示全部楼层
只可能20uA多一点 而且 PMOS处于线性区
发表于 2013-10-22 14:30:32 | 显示全部楼层
很老的一个笔试题目了。
 楼主| 发表于 2013-10-22 18:15:55 | 显示全部楼层
回复 6# 344567112
   这个是某资料中的一个笔试题,具体就那么多参数。。。
GMT+8, 2025-11-2 16:18 , Processed in 0.022176 second(s), 4 queries , Gzip On, Redis On.
