查看: 2683|回复: 4
[讨论] Amplifier Design using PD85004
发表于 2013-8-22 21:14:22 | 显示全部楼层 |阅读模式
I want to design 2 watt amplifier using PD85004 from 135MHz to 175MHz . I am facing problem regarding amplifier stability andmatching. I have simulated amplifier model in ADS 2011.10. for LSSP and load pull test. Physical amplifier does not work with required gain. Can anybody help me ?
发表于 2013-9-4 12:15:43 | 显示全部楼层
With this frequency and bandwidth, you should not have any problems. I work on GHz spectrum and I have yet to face a problem. Although somethings are to be considered here. 1. RF grounding should be proper.
2. The lambda/4 line for DC connectivity should be of the right length.
3.The module should be with same boundary conditions as in the ADS designing software while entering the substrate
 楼主| 发表于 2013-9-18 19:49:24 | 显示全部楼层
回复 2# ayazzakirr
By doing some experiments it is working. I will send you design files for further discussion.
发表于 2013-9-23 09:57:43 | 显示全部楼层
我晕,都是哪的,讲洋文干啥
 楼主| 发表于 2013-10-2 17:33:19 | 显示全部楼层
Can i post ADS simulation files here?
GMT+8, 2025-10-18 07:54 , Processed in 0.025629 second(s), 5 queries , Gzip On, Redis On.
