查看: 15285|回复: 71
[资料] Phaselock Techniques(3rd) by Floyd M. Gardner
发表于 2013-4-11 09:51:36 | 显示全部楼层 |阅读模式
Publication Date: July 29, 2005  | ISBN-10: 0471430633   | ISBN-13: 978-0471430636  | Edition: 3
Author:Floyd M. Gardner
Author:
1   INTRODUCTION 1
1.1   Salient Properties of PLLs  /  2
1.1.1   Bandwidth  /  2
1.1.2   Linearity  /  3
1.2   Organization of the Book  /  3
1.3   Annotated Bibliography  /  3
2   TRANSFER FUNCTIONS OF ANALOG PLLs 6
2.1   Basic Transfer Functions  /  6
2.1.1   Transfer Functions of Individual Elements  /  7
2.1.2   Combined Transfer Functions  /  8
2.1.3   Characteristic Equation  /  9
2.1.4   Nomenclature, Coefficients, and Units  /  9
2.2   Second-Order PLLs  /  10
2.2.1   Loop Filters  /  10
2.2.2   Order and Type  /  12
viiviii CONTENTS
2.2.3   Loop Parameters  /  12
2.2.4   Frequency Response  /  15
2.3   Other Loop Types and Orders  /  20
2.3.1   General Definition of Loop Gain K /  20
2.3.2   Examples of Type 1 PLLs  /  22
2.3.3   Examples of Type 2 PLLs  /  24
2.3.4   Higher-Type PLLs  /  28
Reference /  28
3   GRAPHICAL AIDS 29
3.1   Root-Locus Plots  /  30
3.1.1   Description of Root-Locus Plots  /  30
3.1.2   Stability Criterion  /  33
3.1.3   Root Loci of Type 1 PLLs  /  33
3.1.4   Root Loci of Type 2 PLLs  /  33
3.1.5   Root Loci of Type 3 PLLs  /  34
3.1.6   Root Loci of Higher-Order PLLs  /  35
3.1.7   Effect of Loop Delay on Root Locus  /  38
3.2   Bode Plots  /  38
3.2.1   Presentation Options  /  38
3.2.2   Stability  /  39
3.2.3   Bode Plots of Type 1 PLLs  /  40
3.2.4   Bode Plots of Type 2 PLLs  /  43
3.2.5   Bode Plots of Type 3 PLLs  /  48
3.3   Nyquist Diagrams  /  49
3.4   Nichols Charts  /  49
3.4.1   Stability Criterion  /  49
3.4.2   M-Contours  /  50
3.4.3   Examples of Nichols Charts  /  50
3.5   Closed-Loop Frequency-Response Curves  /  52
Appendix 3A: Salient Features of Root Loci  /  52
3A.1   Branches of Root Loci  /  53
3A.2   Locus on the Real Axis  /  53
3A.3   Locus Intersections with Axes  /  54
Appendix 3B: Formats of the Open-Loop Transfer Function
G(s) /  56
3B.1   Proportional-Plus-Integral Section  /  56
3B.2   High-Frequency Section  /  60
3B.3   Calculations  /  60CONTENTS ix
Appendix 3C: Closed-Loop Frequency Responses  /  61
3C.1   Frequency-Response Formulas  /  61
3C.2   Example Frequency-Response Graphs  /  61
References /  64
4   DIGITAL PLLs: TRANSFER FUNCTIONS AND
RELATED TOOLS 65
4.1   Distinctive Properties of Digital PLLs  /  65
4.2   Digital Transfer Function  /  66
4.2.1   Configuration of a Digital PLL  /  66
4.2.2   Difference Equations  /  67
4.2.3   z-Transforms of the Loop Elements  /  69
4.2.4   Loop Filter  /  70
4.2.5   Loop Transfer Functions  /  71
4.2.6   Poles and Zeros  /  71
4.3   Loop Stability  /  73
4.3.1   Type 1 DPLLs  /  73
4.3.2   Type 2 DPLLs  /  73
4.3.3   Type 3 DPLLs  /  74
4.4   Root-Locus Plots  /  74
4.4.1   Root Loci of Type 1 DPLLs  /  75
4.4.2   Root Loci of Type 2 DPLLs  /  75
4.4.3   Root Loci of Type 3 DPLLs  /  78
4.5   DPLL Frequency Responses: Formulation  /  79
4.6   Bode Plots and Nichols Charts  /  80
4.6.1   Basis of Bode Plots  /  80
4.6.2   Bode Stability Criteria  /  81
4.6.3   Bode Plots of Example DPLLs  /  81
4.6.4   Nichols Chart Example  /  83
4.7   Time-Continuous Approximation for a DPLL  /  85
4.8   Frequency-Response Examples  /  86
4.8.1   Effect of Delay  /  86
4.8.2   Effect of Bandwidth  /  87
4.9   Lowpass Filters in the Loop  /  88
4.9.1   Infinite Impulse Response Lowpass Filter  /  88
4.9.2   Finite Impulse Response Lowpass Filter  /  90
Appendix 4A: Stability of Digital Phaselock Loops  /  91
4A.1   Type 1 DPLL  /  92
4A.2   Type 2 DPLL  /  93
Reference /  96x CONTENTS
5   TRACKING 97
5.1   Linear Tracking  /  97
5.1.1   Steady-State Phase Errors  /  98
5.1.2   Transient Response  /  100
5.1.3   Response to Sinusoidal Angle Modulation  /  109
5.2   Nonlinear Tracking: Lock Limits  /  112
5.2.1   Phase-Detector Nonlinearity  /  112
5.2.2   Steady-State Limits  /  112
5.2.3   Transient Limits  /  114
5.2.4   Modulation Limits  /  118
References /  121
6   EFFECTS OF ADDITIVE NOISE 123
6.1   Linear Operation  /  123
6.1.1   Noise Model of a Phase Detector  /  123
6.1.2   Noise Transfer Function  /  129
6.1.3   Noise Bandwidth  /  129
6.1.4   Signal-to-Noise Ratio in a PLL  /  131
6.1.5   Optimality  /  132
6.2   Nonlinear Operation  /  132
6.2.1   Observed Behavior  /  133
6.2.2   Nonlinear Analysis of Phase Error  /  135
6.2.3   Probability Density and Variance  /  136
6.2.4   Cycle Slips  /  137
6.2.5   Experimental and Simulation Results  /  138
6.2.6   Approximate Analyses  /  138
6.2.7   Miscellaneous Features  /  139
References /  141
7   EFFECTS OF PHASE NOISE 143
7.1   Properties of Phase Noise  /  144
7.1.1   Oscillator Model  /  144
7.1.2   Neglect of Amplitude Noise  /  144
7.1.3   Variance  /  144
7.1.4   Nonstationarity  /  144
7.2   Spectra of Phase Noise  /  146
7.2.1   Theoretical Spectrum W vo (f ) /  146
7.2.2   Normalized Spectrum L (f ) /  147
7.2.3   RF Spectra WRF(f ) and PRF(f ) /  147
7.2.4   Phase-Noise Spectrum W φ (f ) /  149CONTENTS xi
7.2.5   Frequency-Noise Spectrum W ω (f ) /  152
7.2.6   Example Phase-Noise Spectrum  /  152
7.3   Properties of Phase-Noise Spectra  /  153
7.3.1   Typical Continuous Spectra  /  154
7.3.2   Meaning of W φ (f ) /  155
7.3.3   Interpretation of Spectral Displays  /  156
7.3.4   Relationship Between W φ (f ) and L (f ) /  157
7.4   Propagation of Phase Noise  /  159
7.4.1   Phase-Noise Propagation in Auxiliary
Devices  /  159
7.4.2   Phase-Noise Propagation in PLLs  /  161
7.5   Integrated Phase Noise in PLLs  /  162
7.5.1   Basic Formulas  /  162
7.5.2   Excessive Phase Noise  /  163
7.5.3   Effect on Coherent Demodulation  /  163
7.5.4   Bandwidth Trade-off  /  163
7.5.5   Integration  /  164
7.5.6   A Paradox  /  165
7.5.7   Integration of Spectral Lines  /  166
7.5.8   Phase-Noise Specifications  /  166
7.6   Timing Jitter  /  167
Appendix 7A: Analysis of Interference in a Hard
Limiter  /  168
Appendix 7B: Integrals of Untracked Phase Noise  /  169
7B.1   Integration Procedures /  169
7B.2   Results of Integrations  /  169
7B.3   Discussion  /  171
Appendix 7C: Numerical Integration of PLL Phase
Noise  /  171
7C.1   Definition and Application of Integrated Phase
Noise  /  172
7C.2   Data Formats  /  172
7C.3   Data Adjustments  /  173
7C.4   Data Filtering  /  174
7C.5   Numerical Integration  /  174
Appendix 7D: Integration of Discrete Lines in the
Phase-Noise Spectrum  /  175
Appendix 7E: Timing Jitter  /  177
7E.1   Jitter Definitions  /  177
7E.2   Jitter in PLLs  /  179
References /  180xii CONTENTS
8   ACQUISITION OF PHASELOCK 183
8.1   Characterization  /  183
8.2   Phase Acquisition  /  184
8.2.1   First-Order Loop  /  184
8.2.2   Hang-up  /  186
8.2.3   Lock-in  /  186
8.2.4   Aided Phase Acquisition  /  188
8.3   Frequency Acquisition  /  189
8.3.1   Frequency Pull-in  /  189
8.3.2   Frequency Sweeping  /  195
8.3.3   Discriminator-Aided Frequency Acquisition  /  199
8.3.4   Implementation of Frequency
Discriminators  /  203
8.4   Diverse Matters  /  204
8.4.1   Lock Indicators  /  204
8.4.2   Wide-Bandwidth Methods  /  205
8.4.3   Memory  /  206
References /  206
9   OSCILLATORS 209
9.1   Desired Properties  /  209
9.2   Classes of Oscillators  /  210
9.3   Phase Noise in Oscillators: Simplified Approach  /  210
9.3.1   Leeson’s Model  /  210
9.3.2   Guides for Oscillator Design  /  212
9.3.3   Example Phase-Noise Spectra  /  213
9.3.4   Shortcomings of Leeson’s Model  /  214
9.4   Classifications of Oscillators  /  215
9.5   Phase Noise in Oscillators: Advanced Analysis  /  217
9.5.1   Impulse Sensitivity Function  /  218
9.5.2   Nonlinear Analyses for Phase Noise  /  219
9.6   Other Disturbances  /  221
9.7   Types of Oscillator Tuning  /  223
9.7.1   Continuous-Tuning Oscillators  /  223
9.7.2   Discrete-Tuning Oscillators  /  224
9.8   Tuning of Analog VCOs  /  226
9.8.1   Tuning Curve  /  227
9.8.2   Tuning Methods  /  228
9.8.3   Speed of Tuning  /  231
References /  232CONTENTS xiii
10   PHASE DETECTORS 237
10.3.6   Effects of Delay in a PFD  /  254
10.3.7   Extra or Missed Transitions  /  255
10.3.8   Lock Indicator for a PFD  /  256
Appendix 10A: Phase Modulation Due to Phase-Detector
Ripple  /  262
10A.1   Ripple Model  /  262
10A.2   Basis of Analysis  /  263
10A.3   Ripple Examples  /  263
10A.4   Ripple Filters  /  264
References /  265
11   LOOP FILTERS 267
11.1   Active vs. Passive Loop Filters  /  267
11.2   DC Offset  /  268
11.3   Transient Overload  /  269
11.3.1   Overload from PD Ripple  /  269
11.3.2   Overload During Acquisition  /  269
12   CHARGE-PUMP PHASELOCK LOOPS 271
12.1   Model of a Charge Pump  /  271
12.7   Late Developments  /  280
References /  281
13   DIGITAL (SAMPLED) PHASELOCK LOOPS 282
13.1   QuasiLinear Sampled PLLs  /  283
13.2.1   Lessons from Related Studies  /  294
DPLL  /  327
13A.1   Nomenclature  /  327
13A.2   Phase-Detector Operation  /  327
13A.6   Transfer Functions  /  330
13A.7   Transfer Function of a Hold Filter  /  332
References /  333CONTENTS xv
14   ANOMALOUS LOCKING 336
14.1   Sidelocks  /  336
14.1.1   Periodic Modulations  /  337
14.1.2   Cyclostationary Modulations  /  338
14.5   Lock Failures in Chains of PLLs  /  353
References /  354
15   PLL FREQUENCY SYNTHESIZERS 357
15.1   Synthesizer Configurations  /  357
15.1.1   Basic Configuration  /  357
15.1.2   Alternative Configurations  /  359
15.2   Frequency Dividers  /  360
15.2.1   Analog Frequency Dividers  /  361
15.2.2   Digital Counters as Frequency Dividers  /  361
15.3   Fractional-N Counters  /  362
15.3.1   Dual-Modulus Counters  /  362
15.3.2   Fractional-N PLLs with Analog
Compensation  /  364
15.3.3   Fractional-N PLLs with Delta–Sigma
16   PHASELOCK MODULATORS AND DEMODULATORS 380
PhaseLock_Techniques.part2.rar (5.07 MB , 下载次数: 1005 )
PhaseLock_Techniques.part1.rar (9.54 MB , 下载次数: 1039 )
发表于 2013-4-11 09:56:31 | 显示全部楼层
Is this a scan version
 楼主| 发表于 2013-4-11 10:09:54 | 显示全部楼层
回复 2# john_123
    矢量高清~~
发表于 2013-4-11 10:15:00 | 显示全部楼层
太感谢了
 楼主| 发表于 2013-4-11 10:41:14 | 显示全部楼层
自己顶了~~
发表于 2013-4-11 15:28:43 | 显示全部楼层
麻煩以後請標明書名,作者, 書名不是~~Technology!!http://www.amazon.com/Phaselock-Techniques-Floyd-M-Gardner/dp/0471430633
 楼主| 发表于 2013-4-11 15:36:08 | 显示全部楼层
回复 7# brazavi
已修改 谢谢提醒!!!
发表于 2013-4-11 18:49:27 | 显示全部楼层
发表于 2013-4-11 18:53:58 | 显示全部楼层
回复 1# echoas
超级版主 post it before you
发表于 2013-4-13 23:11:07 | 显示全部楼层
2005年的书,有点老了。
GMT+8, 2025-9-15 23:28 , Processed in 0.018955 second(s), 4 queries , Gzip On, Redis On.
