楼主: smilyrong
[求助] 求助:关于ICC中stream gds不能导出filler的问题
发表于 2012-11-26 13:30:58 | 显示全部楼层
回复 2# damonzhao
   你好,我有导出gds文件,set_write_stream_options  -child_depth  99    -output_filling fill   -output_outdated_fill   -output_pin geometry  -keep_data_type ,但是在icfb&导入时却看不到任何的图形,强调gds文件不是空的,谢谢
发表于 2012-11-26 13:58:20 | 显示全部楼层
回复 11# xdfghj
   map文件呢?
发表于 2012-11-26 14:42:10 | 显示全部楼层
回复 12# damonzhao
    你好,我有加上map文件,结果还是同样的问题,可能是我的map文件不对,请问能否告知是什么样的map文件呢?谢谢你。
发表于 2012-11-26 15:41:41 | 显示全部楼层
回复 13# xdfghj
   你可以对照下你的ICC write_stream时的map和virtuoso导入时的map,对应的层次的gds no.是否一致
发表于 2012-11-26 16:09:20 | 显示全部楼层
回复 14# damonzhao
你好,我的map文件内容是这样的, 输出gds时提示每行都是不合法的,我想是不是文件本身的语法不符合ICC的语法要求啊?其中层次对应是正确的。另外是不是说ICC输出gds时一定要map文件?纠结中,麻烦你了,谢谢。
发表于 2012-11-27 09:14:00 | 显示全部楼层
回复 15# xdfghj
    -map_layer layer_mapping_file_name
Specifies the file that defines the layer mapping from Milkyway to GDSII.
The layer mapping file format is
MWObjType[MWNetType][PinCode]
MWLayer[:MWDataType] GDSLayer [GDSDataType]
Valid values for MWObjType are
* A for all types
* T for text
* D for data
Valid values for MWNetType are
* A for all types
* S for signal
* P for power
* G for ground
* C for clock
* U for up conduction layer (upper layer in a via)
* D for down conduction layer (lower layer in a via)
* X for power or ground wires or contacts with a "signal"
or "tie-off" routing type
Valid values for PinCode are
* P means that the pins on each CEL view cell being
processed, which might include child cells depending on
the value of the -child_depth option, are mapped
by this rule.
* T means that only the top-level pins (terminals) on the
current top-level cell are mapped by this rule.
* null
For example, to map the text associated with signal nets on Milkyway layer
10 with a data type of 20 to GDS layer 22 with a data type of 1, enter
TS 10:20 22 1
To map the geometry of METAL1 terminals to GDS layer 15:2 and map the geometry
of lower-level METAL1 pins (not terminals) to GDS layer 14:2, enter
DSP METAL1 14 2
DAT METAL1 15 2
By default, write_stream uses the layer information defined in the Milkyway
database.
发表于 2012-11-27 17:17:08 | 显示全部楼层
回复 17# damonzhao
    惭愧,谢谢你。
发表于 2013-4-18 19:27:21 | 显示全部楼层
学习中,求高人指点,谢谢哈~~~
发表于 2013-12-8 11:59:18 | 显示全部楼层
我好像也遇到了这个问题,不知楼主后来是怎么解决的
GMT+8, 2025-9-11 05:04 , Processed in 0.017801 second(s), 4 queries , Gzip On, Redis On.
