查看: 22850|回复: 26
[求助] 请教一下VCS启动问题。。快纠结死我了。。
发表于 2012-4-1 15:43:21 | 显示全部楼层 |阅读模式
毕设的题目要用VCS,太纠结了。。好不容易装上了但是启动不了。,各种问题。。现在到这个情况我实在不懂了。。求指教
administrator@deepin:~$ vcs top.v add4.v
Warning-[LNX_OS_VERUN] Unsupported Linux version
  Linux version '' is not supported on 'i686' officially, assuming linux
  compatibility by default. Set VCS_ARCH_OVERRIDE to linux or suse32 to
  override.
  Please refer to release notes for information on supported platforms.
Warning-[LINX_KRNL] Unsupported Linux kernel
  Linux kernel '3.0.0-14-generic' is not supported.
  Supported versions are 2.4* or 2.6*.
                         Chronologic VCS (TM)
            Version C-2009.06 -- Sun Apr  1 15:20:52 2012
               Copyright (c) 1991-2008 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Parsing design file 'top.v'
Parsing design file 'add4.v'
Top Level Modules:
       top
No TimeScale specified
Starting vcs inline pass...
1 module and 0 UDP read.
    However, due to incremental compilation, no re-compilation is necessary.
if [ -x ../simv ]; then chmod -x ../simv; fi
g++  -o ../simv  rmapats_mop.o rmapats.o N654_1_d.o SIM_l.o 5NrI_d.o 5NrIB_d.o   /usr/synopsys/C-2009.06/linux/lib/libvirsim.a /usr/synopsys/C-2009.06/linux/lib/librterrorinf.so /usr/synopsys/C-2009.06/linux/lib/libsnpsmalloc.so     /usr/synopsys/C-2009.06/linux/lib/libvcsnew.so     /usr/synopsys/C-2009.06/linux/lib/vcs_save_restore_new.o /usr/synopsys/C-2009.06/linux/lib/ctype-stubs_32.a -ldl  -lc -lm -lpthread -ldl
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsReallocFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsCheckStrdupFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsGetMemBytes'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsCheckMallocFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsFreeGroup'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsGroupGetActive'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsReallocFromGroup'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsNamedPushGroup'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsMemManagerIsActive'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsHighMemory'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsStrdupFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsLowMemory'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsCheckReallocFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsNamedPopGroup'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsCallocFromGroup'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsMallocFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsGroupSize'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsFreeFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsSetOutOfMemoryRoutine'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsCheckFreeFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsMallocFromGroup'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsVPrintf'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsPrintf'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsDoStackUnwind'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsNamedAllocateGroup'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsCheckCallocFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsCallocFunc'
/usr/synopsys/C-2009.06/linux/lib/libvcsnew.so: undefined reference to `snpsCurrentGroup'
collect2: ld 返回 1
make: *** [product_timestamp] 错误 1
Make exited with status 2
CPU time: .024 seconds to compile + 0 seconds to elab + .128 seconds to link
好长的一段话啊。。。那个中间最大段那些什么意思呢?
 楼主| 发表于 2012-4-1 15:46:23 | 显示全部楼层
跪求大神指导
发表于 2012-4-2 14:32:00 | 显示全部楼层
i donot kown
发表于 2012-5-5 23:40:25 | 显示全部楼层
回复 1# duhanyu0516
楼主问题解决没呀?我也遇到同样的问题呀...
发表于 2013-11-20 16:34:20 | 显示全部楼层
也遇到一样问题,楼主解决了么,求指教啊!!!
发表于 2013-11-20 22:55:25 | 显示全部楼层
可能是gcc不匹配
发表于 2013-11-21 08:55:35 | 显示全部楼层
在.bashrc中设置export VCS_ARCH_OVERRIDE=linux,重新启动,应该就可以了!
发表于 2013-11-29 13:56:25 | 显示全部楼层
是系统的安装包不完全吗?
发表于 2013-11-29 20:38:51 | 显示全部楼层
使用./simv,而不是simv,这样就可以simulation了
发表于 2013-12-3 14:54:01 | 显示全部楼层
回复 7# courageheart
   试过没用啊~
GMT+8, 2025-12-23 17:48 , Processed in 0.021497 second(s), 5 queries , Gzip On, Redis On.
