楼主: kongkung
[求助] 有没有达人在Ubuntu下安装过Sentaurus啊,可不可以发个安装方法出来啊!
发表于 2012-3-15 15:11:24 | 显示全部楼层
回复 6# xhwubai
  finally I find it ! Too much thanks!!!
发表于 2012-3-16 10:18:05 | 显示全部楼层
我他妈第一步就运行不起来,用了./setup.sh,不是提示permission denied就是command not found,试了n个linux都没用,都不知道你们是怎么安装成功的
发表于 2012-7-9 17:57:52 | 显示全部楼层
在ubuntu12.04下面可以安装成功!
发表于 2012-7-14 19:36:19 | 显示全部楼层
估计setup.sh文件属性没改吧,要加可执行权限
发表于 2012-8-22 11:01:38 | 显示全部楼层
回复 5# dkslc
    我的机子是64bit的,我把sentaurus common 和amd64放在一个文件夹里无法安装啊?还有SCL也是的
发表于 2012-8-22 11:45:19 | 显示全部楼层
Sentaurus是做什么的?
发表于 2012-8-22 23:42:57 | 显示全部楼层
thanksssss
发表于 2012-8-29 12:00:43 | 显示全部楼层
回复 12# sudezhao
(1) Try command below in Ubuntu command prompt (ROOT password is required to install this):
sudo apt-get install sch
(2) No need to use ===> ./setup.sh    (Depends on the installer version you used!)
(3) Any installer version also able to install Sentaurus! Preferably installer 2.3 or 2.8
(4) Try command below, sure it able to execute:
./installer -gui
Hope this help!
Anything, please email me!
发表于 2012-8-29 13:04:08 | 显示全部楼层
回复 12# sudezhao
    You can try many methods!
(1) In case the command (sudo apt-get install sch) doesn't work on your ubuntu or linux!
(2) Try this command ==> sudo apt-get update && apt-get install sch
If still unable to install, try it using ROOT account!
(3) Btw, after the updates, make sure those required files are mark (or tick) as executable.
It is important! Just right-click to make sure it is executable.
发表于 2012-11-22 15:45:17 | 显示全部楼层
回复 5# dkslc
    thanks for your help!
GMT+8, 2025-12-19 08:38 , Processed in 0.017335 second(s), 4 queries , Gzip On, Redis On.
