楼主: ic_qiand
[2011-11-1][Mentor][Calibre X86 X64 Doc][2011.2_16.14][原创] Calibre一贴搞定...
 楼主| 发表于 2011-11-8 17:18:07 | 显示全部楼层
回复 11# jackzhang
管理员同学,请问咱这样用心又耗时费力发出来的帖子,是不是可以加个精华啥滴给鼓励一下?
 楼主| 发表于 2011-11-8 17:24:19 | 显示全部楼层
回复 20# irwinluo
我的是RHEL WS 6.0,支持的。前一版Calibre2010是不支持RHEL 6.0的。
觉得软件应该是“向下兼容”的原则。
觉得CentOS不就是Redhat的AS、ES、WS的免费版,所以,既然支持RHEL5.0的话,CentOS5应该是没问题的。
发表于 2011-11-11 14:37:54 | 显示全部楼层
xiexie
发表于 2011-11-11 15:09:07 | 显示全部楼层
非常用心,上次软件都装好了结果license出了问题就一直搁置在那里了,如今就在此尝试一下,感谢了哈
 楼主| 发表于 2011-11-11 20:28:39 | 显示全部楼层
回复 24# kylinchan
不谢不谢,如有问题请说明,大家一起试着解决,整理成一个FAQ,方便新人,少走弯路!
发表于 2011-11-11 23:36:26 | 显示全部楼层
非常感谢~~~~
发表于 2011-11-11 23:37:20 | 显示全部楼层
非常感谢
楼主太热心了 ~~~~
发表于 2011-11-12 00:02:08 | 显示全部楼层
Thanks...
发表于 2011-11-12 11:48:19 | 显示全部楼层
我用的操作系统 Red Hat Enterprise Linux Workstation 6.1 版,安装完,提示信息如下:
[root@rayco /]# /usr/local/mentor/calibre/x86_cal_2011.2_34.26/bin/lmgrd -c
/usr/local/mentor/lic/license.dat
6:24:46 (lmgrd) -----------------------------------------------
6:24:46 (lmgrd)   Please Note:
6:24:46 (lmgrd)
6:24:46 (lmgrd)   This log is intended for debug purposes only.
6:24:46 (lmgrd)   In order to capture accurate license
6:24:46 (lmgrd)   usage data into an organized repository,
6:24:46 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
6:24:46 (lmgrd)   software license administration  solution,
6:24:46 (lmgrd)   FLEXnet Manager, to  readily gain visibility
6:24:46 (lmgrd)   into license usage data and to create
6:24:46 (lmgrd)   insightful reports on critical information like
6:24:46 (lmgrd)   license availability and usage. FLEXnet Manager
6:24:46 (lmgrd)   can be fully automated to run these reports on
6:24:46 (lmgrd)   schedule and can be used to track license
6:24:46 (lmgrd)   servers and usage across a heterogeneous
6:24:46 (lmgrd)   network of servers including Windows NT, Linux
6:24:46 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
6:24:46 (lmgrd)   www.acresso.com for more details on how to
6:24:46 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
6:24:46 (lmgrd)   for your enterprise.
6:24:46 (lmgrd)
6:24:46 (lmgrd)
6:24:46 (lmgrd)
6:24:46 (lmgrd) The license server manager (lmgrd) running as root:
6:24:46 (lmgrd)         This is a potential security problem
6:24:46 (lmgrd)         and is not recommended.
6:24:46 (lmgrd) Unknown host: rayco.eda
6:24:46 (lmgrd) EXITING DUE TO SIGNAL 33 Exit reason 1
[root@rayco /]# /usr/local/mentor/calibre/x86_cal_2011.2_34.26/bin/lmstat -c
lmstat - Copyright (c) 1989-2008 Acresso Software Inc. All Rights
Reserved.
Flexible License Manager status on Sat 11/12/2011
06:25
License server status: 1818@rayco.eda
    License file(s) on rayco.eda:
/usr/local/mentor/lic/license.dat:
lmgrd is not running: License server machine is down or not
responding. (-96,7:2 "No such file or directory")
[root@rayco /]# /usr/local/mentor/calibre/x86_cal_2011.2_34.26/bin/calibre -gui
/usr/local/mentor/calibre/x86_cal_2011.2_34.26/bin/calibre:
line 214: basename: command not found
/calibre/x86_cal_2011.2_34.26GC_HOME are different, using
$CALIBRE_HOME=/usr/local/mentor
line 249: sed: command not found
ERROR: Could not find Calibre software tree. Please set $MGC_HOME or
$CALIBRE_HOME.
[root@rayco /]# MGC_HOME=/usr/local/mentor
[root@rayco /]#
CALIBRE_HOME=$MGC_HOME/calibre/x86_cal_2011.2_34.26
[root@rayco /]#
MGLS_LICENSE_FILE=$MGC_HOME/lic/license.datMGLS_LICENSE_FILE
/usr/local/mentor/calibre/x86_cal_2011.2_34.26/bin/calibre: line 214: basename: command not found
WARNING: $CALIBRE_HOME and $MGC_HOME are different, using
$CALIBRE_HOME=/usr/local/mentor/calibre/x86_cal_2011.2_34.26
/usr/local/mentor/calibre/x86_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 75: basename:
command not found
line 235: cat: command not found
/usr/local/mentor/calibre/x86_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 235: sed:
command not found
WARNING: This Linux release is not supported for use with Calibre products.
/usr/local/mentor/calibre/x86_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 260: cat:
command not found
WARNING: Calibre 2010.2 and later will require CPUs which support SSE2
instructions.
  See http://supportnet.mentor.com/systemreqs/calibre.cfm
  To disable this check,
execute:  setenv CALIBRE_DISABLE_SSE2_CHECK YES
请问是什么问题?
发表于 2011-11-12 12:47:27 | 显示全部楼层
我的系统也是Red Hat Enterprise Linux Workstation 6.1 ,请问楼主能装上吗?我装x86_cal_2011.3_18.12_mib时licence失败。用的是2009的license。
我看楼主是用的RHEL6.0的系统。
另外说明,我用RHEL6.0系统主板和显卡都没有驱动,所以换了RHEL6.1系统。老系统上是可以装的,新系统上就不支持了。
有验证过的吗?
请参见http://bbs.eetop.cn/viewthread.php?tid=311204的说明。
GMT+8, 2025-12-19 02:35 , Processed in 0.022604 second(s), 5 queries , Gzip On, Redis On.
