查看: 5158|回复: 7
[求助] 请教高手Astro问题
发表于 2010-8-22 15:32:30 | 显示全部楼层 |阅读模式
在刚开始CTS设置clock common options后,出现一些waring
waring:cell port PO2W/PAD with unknow direction,assumed as input direction
waring:cell port PO2W/I with unknow direction,assumed as input direction
waring:cell port PIW/PAD with unknow direction,assumed as input direction
waring:cell port PIW/C with unknow direction,assumed as input direction
waring: i0: PAD is an implicit ignore pin since it is an non-clock pin
waring: i1: PAD is an implicit ignore pin since it is an non-clock pin
我用的SMIC18工艺,其中PO2W PIW 分别是所用的输出信号PAD、输入信号PAD,
i0,i1是连接两个时钟信号的PAD的实例名
    设置完后,通过clock browse观察时钟树结构,只能看到两个时钟信号连接到i0,i1PAD,但是不连接到摆放在core内部的时序元件的时钟引脚上。
时钟树报告如下
*   Clock Tree Reports
*   Tool    : Astro
*   Version : Z-2007.03-SP10 for SUN.64 -- Jan_06,_2009
*   Design  : pre_cts_copy
*   Date    : Fri Aug 27 20:25:46 2010
======== Clock tree overview ======================================
1. clock clk480
       0 sink pins
       0 gate/macro pins
       1 ignore pins
       0 gate levels
2. clock clk60
       0 sink pins
       0 gate/macro pins
       1 ignore pins
       0 gate levels
Summary
                  total number of clocks : 2
               total number of sink pins : 0
         total number of gate/macro pins : 0
             total number of ignore pins : 2
             maximum number of sink pins : 0
       maximum number of gate/macro pins : 0
           maximum number of ignore pins : 1
           maximum number of gate levels : 0
======== User defined sync pins ======================================
======== Explicit ignored sink pins ======================================
1. clock clk480
2. clock clk60
======== Implicit ignored sink pins ======================================
  C = clock port without trigger edges
  N = non-clock port
  O = open pin
  I = implicit ignore pin
1. clock clk480
  (I) clk480
  (N) i0AD
  (I) i0AD
2. clock clk60
  (I) clk60
  (N) i1AD
  (I) i1:PAD
======== Clock domain overlaps ======================================
发表于 2010-8-22 19:18:05 | 显示全部楼层
How about make a fake *.lib to define PAD cell function/timing?
发表于 2010-8-22 20:09:22 | 显示全部楼层
时钟信号连接到的pin无clock属性
 楼主| 发表于 2010-8-27 18:31:03 | 显示全部楼层
要怎么解决呀?谢谢了
3# zh123456789
 楼主| 发表于 2010-8-29 15:56:35 | 显示全部楼层
自己顶
发表于 2010-11-2 23:53:23 | 显示全部楼层
呵呵,学习了。
发表于 2011-3-29 09:50:50 | 显示全部楼层
学习了。。。。。。。。。。。。。。
发表于 2011-3-29 11:16:34 | 显示全部楼层
xiexie!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
GMT+8, 2025-12-5 19:27 , Processed in 0.017255 second(s), 4 queries , Gzip On, Redis On.
