查看: 20789|回复: 110
【平面天线86篇】最全的天线 E文 论文(86篇)
发表于 2009-7-1 22:56:28 | 显示全部楼层 |阅读模式
最近搜集了一些国内外研究平面天线方向的论文,
主要都是手机天线,UWB天线,平面天线方向的,
需要的兄弟尽管下载,
支持的话就给个回复,
对我来说也是一种鼓励,呵呵
      65M    12个压缩包
下面是目录:
hand effect
1. Tunable planar inverted-F antenna using rf MEMS switch for the reduction of human hand effect
2. Designing ground plane to reduce hand effects on mobile handsets
3. User's hand effects on EMC internal GSM/DCS mobile phone antenna
4. Feeding point determination regarding hand effect of PIFA for mobile RFID band
5. Some experimental results for the head/hand effects in personal communications
6. Some experimental results for the head/hand effects in personal communications(??? ??)
7. A Compact Wideband Planar Diversity Antenna Covering UMTS and 2.4 GHz WLAN Bands
8. Automatic antenna tuning for RF transmitter IC applying high Q antenna
9. Performance of a Multiband Diversity Antenna with Hand Effects
10. Internal Patch Antenna With a Thin Air-Layer Substrate for GSM/DCS Operation in a PDA Phone
11. Internal Compact Dual-Band Printed Loop Antenna for Mobile Phone Application
12. An analysis of the performance of a handset diversity antenna influenced by head, hand, and shoulder effects at 900 MHz .II. Correlation characteristics
13. An analysis of the performance of a handset diversity antenna influenced by head, hand, and shoulder effects at 900 MHz .I. Effective gain characteristics
14. Exploiting the Effects of Human Hands on the Radiation Characteristics for the Implementation of Self-adaptive Feed Circuit of Offset-fed Slot Antennas in Parallel for the Reception of Digital Terrestrial TV Broadcasting
15. Design of a 900/1800 MHz dual-band loop antenna mounted on a handset considering the human hand and head effects
intenna
16. Feeding point determination for PIFA type mobile phone handset internal antenna
17. Theoretical study of angular distribution of plane waves in a small reverberation chamber for simulating multipath environment and testing mobile phones
internal antenna
18. A mobile antenna study of radiation efficiency in human head and hand environment
19. Radiation Pattern of a 2.4/ 5.2GHz Laptop Internal Antenna: Near Field Spherical Range Measurements and Full Wave Analysis
20. Feeding point determination for PIFA type mobile phone handset internal antenna
21. Investigation of SAR of an internal antenna of mobile phones
22. A dual-band internal antenna with a parasitic patch for mobile handsets and the consideration of the handset case and battery
23. A wideband internal antenna with dual monopole radiation elements
24. Hepta-Band Internal Antenna for Personal Communication Handsets
25. A New Compact Hexaband Internal Antenna of the Planar Inverted F-Type for Mobile Handsets
26. Design of a Compact Internal Antenna for Multi-Band Personal Communication Handsets
27. Design of a novel multiband internal antenna for personal communication handsets
28. Dual-band internal antenna of PIFA type for mobile handsets and the effect of the handset case and battery
29. A triple-band internal antenna for mobile hand-held terminals
30. A new enhanced-bandwidth internal antenna for portable communication systems
31. A Simple PIFA-Based Tunable Internal Antenna for Personal Communication Handsets
32. Study and design of a capacitively coupled polymeric internal antenna
33. Design of a multiband internal antenna for third generation mobile phone handsets
34. A triple-band internal antenna: design and performance in presence of the handset case, battery, and human head
35. TDMB/AMPS/GSM/DCS/PCS/SDMB internal antenna using parasitic element with switching circuit
36. Multiband internal antenna for mobile phones
37. A compact internal antenna for wireless USB dongle application
38. Design of a multi-band internal antenna using an open stub
39. A miniature wideband internal antenna with dual resonant structures
40. A Quad-Band Internal Antenna Having Independent Controllability of Low/High Resonant Frequencies
41. Compact internal antenna using a ferrite material for DVB-H reception in mobile phones
42. Design of an ultra-wideband internal antenna using symmetrical radiators for mobile application
43. Broadband internal antenna of planar monopole type for mobile handsets
44. Multi-band internal antenna including DVB-H band
45. A dual-band internal antenna of PIFA type for bluetooth/WLAN in mobile handsets
46. Internal antenna for multiband mobile handset applications
47. Triple band internal antenna using matching circuits
48. Triple band internal antenna with a novel feeding structure
49. The effects of the handset case, battery, and human head on the performance of a triple-band internal antenna
50. Planar inverted-F antenna with a hollow shorting cylinder for internal mobile phone antenna
51. Bandwidth and radiation properties of internal handset antennas
52. Progress of multi-band antenna technology in mobile phone industry
53. Multiband Printed Monopole Slot Antenna for WWAN Operation in the Laptop Computer
54. Internal GSM/DCS antenna backed by a step-shaped ground plane for a PDA phone
55. Internal Ultrawideband Monopole Antenna for Wireless USB Dongle Applications
56. New compact six-band internal antenna
57. Uni-Planar Dual-Band Monopole Antenna for 2.4/5 GHz WLAN Operation in the Laptop Computer
58. Multiband antenna with parasitic branches for laptop applications
59. Internal antenna with modified monopole type for DVB-H applications
60. Small internal antennas for indoor UMTS base station with WLAN access point
61. Shorted Monopole Dual Band Antenna for Ultra-Thin Profile Slider Mobile Phone
62. Compact Five Band Internal Antenna for Mobile Phone
63. Radio and antenna integration for mobile platforms
64. Internal antenna for UHF-band mobile RFID system
65. Monopole antenna fed by a coaxial cable in slide phone for GSM/DCS/PCS operation
66. A compact quad-band PIFA by using defected ground structure
67. Designing ground plane to reduce hand effects on mobile handsets
68. Folded planar monopole internal antenna for multi-band mobile phones
69. A design of wide band small chip antenna using the branch structure for mobile phone
70. A design of miniaturized built-in penta band chip antenna for EGSM/GPS/DCS/USPCS/WCDMA Mobile Handset
71. An embedded tri-band planar inverted-F antenna with a branch-line shorting strip
72. The folded inverted conformal antenna (FICA) for multi-band cellular phones
73. Meandered planar inverted-F antenna for PCS mobile phone
74. New type of small broad-band internal antenna for third generation mobile phone handsets
75. Metal-plate shorted T-shaped monopole for internal laptop antenna for 2.4/5 GHz WLAN operation
76. Dual and wide band internal planar antenna for wireless LAN
77. A design of an antenna for KPCS/IMT-2000 dual-band applications
78. Small Antennas for Hyperthermia
79. Slot Antennas With an Extended Ground for Multiple-Antenna Systems in Compact Wireless Device
80. A Compact Tunable Internal Antenna for Personal Communication Handsets
81. Design of a planar inverted-F Antenna with very wide impedance bandwidth
82. A broadband interior antenna of planar monopole type in handsets
83. Printed Loop Antenna With a Perpendicular Feed for Penta-Band Mobile Phone Application
84. Dual-band planar inverted F antenna for GSM/DCS mobile phones
85. GSM/DCS/IMT-2000 triple-band built-in antenna for wireless terminals
86. EMC internal patch antenna for UMTS operation in a mobile device
87. Dual-band flat-plate antenna with a shorted parasitic element for laptop applications
88. Radio frequency electromagnetic fields in large conducting enclosures: effects of apertures and human bodies on propagation and field-statistics
89. Internal Compact Dual-Band Printed Loop Antenna for Mobile Phone Application
90. Octa-band internal monopole antenna for mobile phone applications
91. Design concept of multi-band antenna with resonant circuit on PCB
92. Novel internal multi-antenna configuration employing folded dipole elements for notebook PC
enjoy  it。。。。
【平面天线】最全的天线论文(86篇).part12.rar
2 MB, 下载次数: 432 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-7-1 23:17:48 | 显示全部楼层
97
抱歉网速太慢了,先占个位
[ 本帖最后由 tianxian 于 2009-7-2 10:24 编辑 ]
【平面天线】最全的天线论文(86篇).part05.rar
4.67 MB, 下载次数: 403 , 下载积分: 资产 -3 信元, 下载支出 3 信元
【平面天线】最全的天线论文(86篇).part04.rar
4.67 MB, 下载次数: 381 , 下载积分: 资产 -3 信元, 下载支出 3 信元
【平面天线】最全的天线论文(86篇).part03.rar
4.67 MB, 下载次数: 376 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2009-7-1 23:22:00 | 显示全部楼层
thanks for sharing
thanks for sharing
 楼主| 发表于 2009-7-1 23:32:35 | 显示全部楼层
97
【平面天线】最全的天线论文(86篇).part11
【平面天线】最全的天线论文(86篇).part10
[ 本帖最后由 tianxian 于 2009-7-2 00:13 编辑 ]
【平面天线】最全的天线论文(86篇).part11.rar
【平面天线】最全的天线论文(86篇).part10.rar
4.67 MB, 下载次数: 367 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2009-7-1 23:50:42 | 显示全部楼层
【平面天线】最全的天线论文(86篇).part9
【平面天线】最全的天线论文(86篇).part8
【平面天线】最全的天线论文(86篇).part7
【平面天线】最全的天线论文(86篇).part6
[ 本帖最后由 tianxian 于 2009-7-6 07:31 编辑 ]
【平面天线】最全的天线论文(86篇).part09.rar
4.67 MB, 下载次数: 352 , 下载积分: 资产 -3 信元, 下载支出 3 信元
【平面天线】最全的天线论文(86篇).part08.rar
4.67 MB, 下载次数: 373 , 下载积分: 资产 -3 信元, 下载支出 3 信元
【平面天线】最全的天线论文(86篇).part07.rar
4.67 MB, 下载次数: 345 , 下载积分: 资产 -3 信元, 下载支出 3 信元
【平面天线】最全的天线论文(86篇).part06.rar
4.67 MB, 下载次数: 324 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2009-7-2 10:25:28 | 显示全部楼层
继续
【平面天线】最全的天线论文(86篇).part02.rar
4.67 MB, 下载次数: 354 , 下载积分: 资产 -3 信元, 下载支出 3 信元
【平面天线】最全的天线论文(86篇).part01.rar
4.67 MB, 下载次数: 356 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2009-7-2 10:45:13 | 显示全部楼层
001【阵列天线】关于阵列方面的7篇研究生硕士论文
宽带相控阵天线综合.PDF
宽带阵列综合方法研究.PDF
阵列方向图综合和自适应波束形成研究.PDF
阵列天线方向图综合方法及起在有源相控阵中的应用.PDF
阵列天线方向图综合算法研究.PDF
阵列天线综合方法研究.PDF
自适应波束形成算法的分析与研究.PDF
002  【成电】【阵列天线讲义】王建教授的.rar
下载页面
http://www.eetop.cn/bbs/viewthread.php?tid=179969&pid=2489292&page=1&extra=page%3D7#pid2489292
003【微带天线】28篇   西文期刊论文
A Broad-Band U-Slot Rectangular PatchAntenna.pdf
A Compact Microstrip Square-Ring SlotAntenna for UWB .pdf
A Double-Sided Printed Y-Shaped DipoleAntenna .pdf
A NEW PLANAR CIRCULAR DISC-AND-.pdf
A NOVEL COMPACT PRINTED.pdf
A Wide-Band Shorted Planar Monopole WithBevel.pdf
AN ULTRA-WIDEBAND STACKED.pdf
Bandwidth Enhancement of a Microstrip.pdf
Broadband Planar Antenna Having RoundCorner.pdf
Improved U-shaped stub rectangular.pdf
LEAF-SHAPED MONOPOLE ANTENNA.pdf
Micro-strip Patch Antenna Primer.pdf
MINIATURIZED BROADBAND MICROSTRIP ANTENNAS.pdf
Planar elliptical antenna forultra-wideband.pdf
Printed Elliptical Circular SlotAntennas.pdf
ETC
ENJOY  IT
004再送上  12篇  中文微带天线小论文
E形宽带微带天线的时域有限差分法分析.pdf
宽带微带天线理论与设计方法.pdf
宽带圆极化微带天线的几种实现方法.pdf
宽带锥形缝隙微带天线的研究与设计.pdf
宽缝微带天线阻抗特性的时域有限差分法分析.pdf
平面超宽带天线的设计与研究.pdf
微带天线的设计和阻抗匹配.pdf
一种U型宽带微带天线的设计与制作.pdf
一种宽带贴片天线的设计与仿真.pdf
一种宽带微带贴片天线的新设计.pdf
一种小型平面超宽带天线的设计与研究.pdf
一种新颖的超宽带楔形微带准喇叭天线设计.pdf
下载页面
http://www.eetop.cn/bbs/thread-179966-1-1.html
[ 本帖最后由 tianxian 于 2009-7-15 12:57 编辑 ]
 楼主| 发表于 2009-7-2 19:47:21 | 显示全部楼层
:hug:
搞天线的不多吧
发表于 2009-7-3 20:50:45 | 显示全部楼层
thanks for sharing
 楼主| 发表于 2009-7-6 07:32:10 | 显示全部楼层
顶起来
GMT+8, 2025-9-14 21:30 , Processed in 0.035598 second(s), 6 queries , Gzip On, Redis On.
