我在ubuntu8.04.1下安装了DC2007 ,PT2005,正确配置了license和启动脚本.bashrc,license可以启动,输入dv&,可以正确启动DC2007,使用也没问题;但是输入pt&后,就会出现如下问题(以前在CentOS4.6下就没有这个问题,但在CentOS4.6下DC2007不能使用):
PrimeTime (R)Version X-2005.12 for linux -- Nov 21, 2005
Copyright (c) 1988-2005 by Synopsys, Inc.
ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys, Inc.and may be used and disclosed only
as authorized in a license agreement controlling such use and disclosure.
No entry for terminal type "xterm";
using dumb terminal settings.
The tool has just encountered a fatal error:
If you encountered this fatal error when using the most recent Synopsys release, submit this stack trace and
a test case that reproduces the problem to the Synopsys Support Center by using Enter A Call at
http://solvnet.synopsys.com/EnterACall.
For information about the latest software releases, go to the Synopsys SolvNet Release Library at
http://solvnet.synopsys.com/ReleaseLibrary.
For information about required Operating System patches, go to
http://www.synopsys.com/qrsc.
For instructions for creating, packaging, and sending a test case, go to
http://www.synopsys.com/testcase.
Fatal: Internal system error, cannot recover.Error code=6
Release = 'X-2005.12' Architecture = 'linux' Program = 'pt_shell
152614955 152615183 -1209072608 -1212020223 150609348 150609404 150609404 150608652 150623781 150624885
150593919 150593352 150587928 150566465 137358824 137356887 134587685 135320558 135298867 134587859
134559045'
我认为主要问题在这里:No entry for terminal type "xterm";
后边不是说了吗:Fatal: Internal system error, cannot recover.Error code=6 内部系统错误,无法恢复,错误代码=6
估计是linux系统的问题。哪位linux大牛能告诉我 xterm终端的入口是什么。什么是dumb terminal settings?如何设置?
以前在CentOS4.6下就没有这个问题。 |
