查看: 6149|回复: 4
关于PT2005
发表于 2008-11-27 04:28:55 | 显示全部楼层 |阅读模式
我在ubuntu8.04.1下安装了DC2007 ,PT2005,正确配置了license和启动脚本.bashrc,license可以启动,输入dv&,可以正确启动DC2007,使用也没问题;但是输入pt&后,就会出现如下问题(以前在CentOS4.6下就没有这个问题,但在CentOS4.6下DC2007不能使用):
PrimeTime (R)Version X-2005.12 for linux -- Nov 21, 2005
  Copyright (c) 1988-2005 by Synopsys, Inc.
ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys, Inc.and may be used and disclosed only
as authorized in a license agreement controlling such use and disclosure.
No entry for terminal type "xterm";
using dumb terminal settings.
The tool has just encountered a fatal error:
If you encountered this fatal error when using the most recent Synopsys release, submit this stack trace and
a test case that reproduces the problem to the Synopsys Support Center by using Enter A Call  at
http://solvnet.synopsys.com/EnterACall.
  For information about the latest software releases, go to the Synopsys SolvNet Release Library at
http://solvnet.synopsys.com/ReleaseLibrary.
  For information about required Operating System patches, go to
  http://www.synopsys.com/qrsc.
For instructions for creating, packaging, and sending a test case, go to
http://www.synopsys.com/testcase.
Fatal: Internal system error, cannot recover.Error code=6
Release = 'X-2005.12'  Architecture = 'linux'  Program = 'pt_shell
152614955 152615183 -1209072608 -1212020223 150609348 150609404 150609404 150608652 150623781 150624885
150593919 150593352 150587928 150566465 137358824 137356887 134587685 135320558 135298867 134587859
134559045'
我认为主要问题在这里:No entry for terminal type "xterm";
后边不是说了吗:Fatal: Internal system error, cannot recover.Error code=6 内部系统错误,无法恢复,错误代码=6
估计是linux系统的问题。哪位linux大牛能告诉我 xterm终端的入口是什么。什么是dumb terminal settings?如何设置?
以前在CentOS4.6下就没有这个问题。
发表于 2009-7-2 20:38:06 | 显示全部楼层
不知道啊
发表于 2012-12-11 14:51:16 | 显示全部楼层
回复 1# liude19832006
你好,请问你这个问题解决了么?
 楼主| 发表于 2012-12-11 15:12:18 | 显示全部楼层
回复 3# yameide16
   系统的问题。主要就是系统的兼容性不好,选择RHEL就什么问题都没有了。
发表于 2013-5-28 16:19:52 | 显示全部楼层
我的pt在fedora也有问题
GMT+8, 2025-12-20 04:42 , Processed in 0.022692 second(s), 5 queries , Gzip On, Redis On.
