查看: 31183|回复: 49
DC安装磨难记
发表于 2008-8-23 17:52:10 | 显示全部楼层 |阅读模式
今日使用了dc2007.03-SP1,出现不少问题,不知道没有大牛们以前有没有遇到过,好解决不:
环境:rhel3;本机MAC:000c290e7487;主机名:localhost.localdomain
SCL版本:10.9.1d,安装:SynopsysInstaller-V2.0;
dc2007.03-SP1安装至/synopsys/dc2007;安装时Site ID用默认的123,(用000时也一样);Site Administrator填localhost.localdomain(空着不填也一样);Contact information默认root@(none)不动;
license制作方法:使用EFALic制作synopsys.dat(已用synopsys.src替换packs包里的synopsys.src);用sssverify.exe算出SECRET DATA = 026d 0000 d9fe 0000 c000(大家算出来的应该也是这个SECRET DATA 吧);用SSSFeatureKeyGen生成license.dat;
用license.dat里的FEATURE SSS替换掉synopsys.dat里的FEATURE SSS;
最终的synopsys.dat:
SERVER localhost.localdomain 000c290e7487 27000
DAEMON snpslmd /synopsys/scl/linux/bin/snpslmd
PACKAGE EFA_Synopsys_1 snpslmd 2019.12 D0509041F384D15BBF2C COMP69656 d1d88 34cc3 38a6f 538ce df1f2 30f43 8258f \
        ecc22 fcf" HOSTID=000c290e7487 ISSUER="Team ZWT 2006" \
        NOTICE="Licensed to mammoth//ZWT 2006 [PLEASE DO NOT DELETE THIS \
        SSS KEY]" SN=RK:1978-0:001224:0 START=1-jan-2006
在/etc/rc.local里添加/synopsys/scl/linux/bin/lmgrd -c  /synopsys/license/synopsys.dat -l /synopsys/license/synopsys.log
环境设置.bashrc为:
export PATH=/synopsys/dc2007/binPATH
export SNPSLMD_LICENSE_FILE=27000@localhost.localdomain
export LM_LICENSE_FILE=/synopsys/license/synopsys.datMGC_LICENSE_FILE
alias dv='/synopsys/dc2007/bin/design_vision'
开机后lmgrd记录的log后几行:
13:39:55 (snpslmd)         ==>FEATURE ATMWB_UTOPIA snpslmd 2019.12 31-dec-2019 uncounted \
        9DE83F668BD8432D34C0 VENDOR_STRING=^1Platform:ALL+S \
        HOSTID=000c290e7487 SUPERSEDE ISSUER="Team EFA 2001" \
        ISSUED=11-jul-2001 ck=249 SN=SL:2100-0:100000:0 \
        START=11-jul-2001
13:39:55 (snpslmd) Server started on localhost.localdomain for:        SSS
13:39:55 (snpslmd)
13:39:55 (snpslmd) Licenses are case sensitive for TE_CATS
13:39:55 (snpslmd)
13:39:55 (lmgrd) snpslmd using TCP-port 32770
13:39:55 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  slat  ssilmd  synopsysd  tmald  vcsd
13:39:56 (snpslmd) ------------------------------------------------------------------
13:39:56 (snpslmd) Checking the integrity of the license file....
13:39:56 (snpslmd) Valid SSS feature found.
13:39:56 (snpslmd) The feature is needed to enable the other keys in your license file.
在终端输入dv后的提示:
[root@localhost root]# dv
Unable to obtain feature 'Design-Vision ' because:
Error: This site is not licensed for 'Design-Vision'. (SEC-51)
Please contact localhost.localdomainl at root@(none), who is
your local Synopsys license administrator for Synopsys site 123.
Unable to obtain feature 'Design-Analyzer-DAP ' because:
Error: This site is not licensed for 'Design-Analyzer-DAP'. (SEC-51)
Unable to obtain feature 'Design-Analyzer ' because:
Error: This site is not licensed for 'Design-Analyzer'. (SEC-51)
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer-DAP, Design-Analyzer. (DCSH-10)
若输入dc_shell与dc_shell-t:
[root@localhost root]# dc_shell
Fatal: Design Compiler is not enabled. (DCSH-1)
[root@localhost root]# dc_shell-t
不晓得我哪里弄错了,折腾了好几天始终无法解决,实在是没办法了不知有哪位大牛愿意指点错误,不胜感激.
发表于 2008-9-23 23:29:45 | 显示全部楼层
license not working
发表于 2008-10-20 15:03:28 | 显示全部楼层
license有问题
发表于 2008-12-22 22:52:47 | 显示全部楼层
好向是SYNOPSYS_HOME的变量没设定好
发表于 2009-1-4 18:21:54 | 显示全部楼层
feature不全
发表于 2009-3-6 09:12:08 | 显示全部楼层
发表于 2009-3-11 17:20:25 | 显示全部楼层
换个license破解法试试, 感觉是license的问题
发表于 2009-3-11 18:26:21 | 显示全部楼层
等你装好了, 告诉大家一下你的经验
发表于 2009-3-14 11:33:04 | 显示全部楼层
Error: Internal licensing error number -42: Invalid parameter
Feature:       Design-Analyzer
License path:  [email=27000@happyAS4]27000@happyAS4[/email]
FLEXlm error:  -42,147
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".. (SEC-17)
我的,也没有搞定,换了几个license都一样
发表于 2009-4-14 16:05:01 | 显示全部楼层
能不能发个安装教程上来??
GMT+8, 2025-12-17 12:05 , Processed in 0.023868 second(s), 6 queries , Gzip On, Redis On.
