查看: 8838|回复: 49
High-Efficiency Low-Voltage DC-DC Conversion for Portable-- UC Berkeley 博士論文
发表于 2008-7-13 09:48:26 | 显示全部楼层 |阅读模式
內容如下: Table of Contents Chapter 1: Introduction ....................................................................................................1
1.1 Motivation.....................................................................................................................1
1.2 The Challenge of Lower-Voltage DC-DC Conversion ..................................................3
1.2.1 Low-Voltage and High-Current.................................................................................................4
1.2.2 Low-Voltage and Low-Current .................................................................................................5
1.3 Research Goals and Contributions.................................................................................7
1.4 Thesis Organization .......................................................................................................8
Chapter 2: DC-DC Conversion as a Low-Power Enabler ...........................................10
2.1 Voltage Scaling for Low-Power...................................................................................11
2.1.1 Multiple Supply Voltages ........................................................................................................13
2.1.2 Architectural Voltage Scaling..................................................................................................14
2.1.3 Voltage Scaling with Vt Reduction .........................................................................................17
2.1.4 Discussion ...............................................................................................................................18
2.2 Dynamic Voltage Scaling for Energy-Efficient GPP...................................................18
2.2.1 Typical Processor Usage .........................................................................................................19
2.2.1.1 Sleep Mode ............................................................................................................20
2.2.1.2 Slow Clocks ...........................................................................................................21
2.2.2 Dynamic Voltage Scaling ........................................................................................................22
2.2.3 Discussion ...............................................................................................................................24
2.3 Low-Swing Interconnect..............................................................................................25
2.3.1 Discussion ...............................................................................................................................27
2.4 Voltage Regulation Enhances Battery Run-Time ........................................................28
2.4.1 A Piecewise Linear Model to a Low-Rate Battery Discharge Curve......................................30
2.4.2 Models for Battery Loading Conditions..................................................................................32
2.4.3 Case Study: An Analog Load with Supply-independent Biasing ...........................................33
2.4.3.1 Run directly from the cell ......................................................................................34
2.4.3.2 Run through a linear regulator ...............................................................................34
2.4.3.3 Run through a switching regulator.........................................................................34
2.4.4 Case Study: A Throughput-constrained Digital CMOS Load.................................................35
2.4.4.1 Run directly from cell ............................................................................................35
2.4.4.2 Run through a linear regulator ...............................................................................35
2.4.4.3 Run through a switching regulator.........................................................................36
2.4.5 Results .................................................................................................................. ...................36
2.4.6 Converter Size vs. Extra Battery Size .................................................................................... .39
Chapter 3: DC-DC Converter Fundamentals ...............................................................42
Chapter 4: DC-DC Design Techniques for Portable Applications..............................79
Chapter 5: Design Considerations for Dynamic DC-DC Converters .......................124
Chapter 6: Prototype DC-DC Converters ...................................................................147
Chapter 7: Conclusions .................................................................................................228 References......................................................................................................................231
[ 本帖最后由 keroppi 于 2009-5-24 09:07 编辑 ]
High-Efficiency Low-Voltage DC-DC Conversion for Portable. Applications__Berkeley博論.pdf
2.02 MB, 下载次数: 478 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-13 09:49:34 | 显示全部楼层
自己頂一個
发表于 2008-7-13 12:10:04 | 显示全部楼层
thank you
发表于 2008-7-16 00:07:22 | 显示全部楼层
看看怎么样
头像被屏蔽
发表于 2008-7-16 09:07:03 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-7-16 10:37:07 | 显示全部楼层
难得楼主还将目录贴出来了,支持!!!
 楼主| 发表于 2008-8-10 23:48:02 | 显示全部楼层
好東西 多謝了
发表于 2008-8-11 09:39:19 | 显示全部楼层
:victory:
发表于 2008-9-4 22:13:31 | 显示全部楼层
发表于 2008-9-5 11:38:50 | 显示全部楼层
thanks
GMT+8, 2025-9-15 06:22 , Processed in 0.026843 second(s), 8 queries , Gzip On, Redis On.
