楼主 |
发表于 2008-5-4 15:43:11
显示全部楼层
Power Distribution Network Design For VLSI
This book provides the detailed information on power distribution
network design in integrated circuit chips. Power distribution
network design is a critical part of the job in circuit design and
physical integration for high-speed chips.
The IR drop and di/dt noise associated with the power distribution
networks are crucial to circuit timing and performance. Due
to the complexity of the millions of gates and interconnects in
modern VLSI chips, power network analysis is accomplished using
CAD tools. These tools take the layout database, usually in
GDSII files, extract the RC parasitic for the power distribution
network, and model the current consumption for switching devices.
A fast circuit simulation is done for the electrical model of the
power distribution network in order to determine the IR drop or
other supply voltage noises, as well as the current density of metal
power lines for checking electromigration failures.
In addition, the decoupling capacitors are inserted into the
power network for stabilizing the supply voltages in local regions
where current surges occur from time to time due to clock and logic
operations. The decoupling capacitors and power distribution
networks are required in some optimal form not only on-chip, but
also on the package and at system levels.
This book will explain the design issues, guidelines, examples,
and CAD tools for the power distribution of the VLSI chip and
package. The user guide of the VoltageStorm™ tool from Cadence
Design Systems, Inc. is referred to throughout [51], together with
the author’s experience using this tool in designs.
The book is organized into seven chapters. Chapter 1 is an introduction
to the power supply network, power network modeling,
decoupling capacitors, and process scaling trends. Chapter 2 illustrates
the design perspectives for the power distribution network,
including power network planning, layout specifications, decoupling
capacitance insertion, modeling and analysis of power networks,
and IR drop analysis and reduction. Chapter 3 explores
electromigration phenomena for the on-chip power distribution
network.
Chapter 4 discusses IR drop analysis methodology. It is taken
primarily from the VoltageStorm™ tool, using both static and dynamic
analysis methods. The static method is performed for some
level worst-case IR drop analysis without the knowledge of input
vectors at the chip’s primary inputs. Chapter 5 describes the commands
and user interfaces of the VoltageStorm™ tool from Cadence
Design Systems, Inc. [51]. Chapter 6 lists the microprocessor
design examples, with a focus on on-chip power distribution.
Readers will gain the insights into industry chip design for power
distribution networks from these examples.
Chapter 7 discusses the flip-chip and package design issues,
since the package is a part of the global power distribution. A case
study has been provided in this chapter for selecting the package
options, based on the performance requirements for the power
supply. Power network measurement techniques from silicon are
also discussed at the end of Chapter 7.
A glossary of key words and basic terms is provided at the end
of the book to help understand the basic concepts in VLSI design
and power distribution.
With the continually decreasing supply voltages and the increasing
transistor switching currents on-chip, power supply noises
on-chip remains the challenging issue for high-performance
chip design. More and more research will be needed in the future
in CAD tools for switching current modeling and accurate power
network analysis. The design methodology for power delivery will
need to consider the performance, layout area, and package technology
optimization for future chips.
The author would like to thank Mr. George J. Telecki at John
viii PREFACE
Wiley & Sons, Inc. for providing the chance to get this book published.
He also thanks his co-workers in Intel Corporation, including
David Ayers, Alex Waizman, and Bendik Kleveland. Finally,
he appreciates the strong support from family members, including
wife Huiling Song and two sons Phillip and Michael |
