查看: 179|回复: 2
[求助] SMIC IO 库导入.sp原理图map文件对应问题
发表于 2025-12-6 15:51:13 | 显示全部楼层 |阅读模式
悬赏50资产未解决
使用SMIC 标准IO库中单元PANA2APW,在导入原理图网表时,发现其网表中有一个器件(C2)如图,请问map文件应该对应为什么器件呢?尝试继续填写C2遇到如下错误:填写为n33时可导入器件,但LVS报错,原因是LVS网表中此器件自动识别为C2,请问这个C2应该对应什么器件呢?应该怎样保证LVS检查正确
No subckt parameters for this module
        Instance: M2
        Instance has master: 'mos' model/subtype: 'C2'
                Master Cell 'mos[C2]' mapped to 'C2'.
                Did not find 'smic18mmrf.C2:symbol'.
ERROR (SPICEIN-24): Spice In did not find the symbol view of the master cell 'mos' of the instance
'M2' in the subcircuit 'PANA2APW'. Specify the reference library that has the symbol
view of the master cell, or use device-mapping to map 'mos' to a different cell.
Some device mapping file examples for commonly used components while importing
发表于 2025-12-11 21:43:53 | 显示全部楼层
看下LVS rule的开头部分
发表于 5 小时前 来自手机 | 显示全部楼层
同问,请问楼主解决了吗?
GMT+8, 2025-12-29 06:17 , Processed in 0.025223 second(s), 4 queries , Gzip On, Redis On.
