查看: 549|回复: 26
Verification VM 2022 tools
发表于 2025-11-28 10:52:32 | 显示全部楼层 |阅读模式
Hope you are doing well this Verification VM that has almost all you might need from $yn0p , C@d , Mentor: I used 2022 version as it is the newest most stable version till now
I used the VM & many sources from this post
https://bbs.eetop.cn/thread-997913-1-1.html
my bashrc
bashrc.txt (5.33 KB , 下载次数: 47 )
Modified Cadence Lic (adding new features)
cadence.rar (4.62 KB , 下载次数: 55 )
Modified Synopsys Lic (adding new features)
synopsys.rar (13.96 KB , 下载次数: 53 )
OS: CentOS 7.9
Hard drive free space for VMDK: you will need 120 GB
RAM: at least 8GB assigned for it
Processors: 2 with 2 threads
For the first time I used it, I moved it
VM workstation 2025 is free, you don't need key / patch just download it and install it to use the VM
Reminder: For preventing your vm from freeze in windows 11
* Change Power Plan: Control Panel → Power Options -> Set to "High Performance" or "Ultimate Performance"
* Visual Effects: System Properties →Performance Options -> Set to "Adjust for best performance"
* Run VM workstation as admin
Installed:
VSCode: (Icon in Desktop) don't update it because higher version dosen't support centos 7.9 + I added Codeium is a free AI code assistant (log in with your account)
Ecludie Synopsys 2024 : (Icon in Desk top) but I didn't manage to crack it well
/home/eda/mentor
└── questasim2021 -> ok
/home/eda/cadence
├── INDAGO2209 -> not tested
├── Installer
├── JASPER2212 -> jaspergold (ok)
├── JEDAI231 -> Cracked but not tested
├── VAPPS2209 -> cracked but not tested
├── VDEBUG2209 -> Cracked but not tested
├── VIPCAT113 -> Cracked but not tested (11.03.037 version)
├── VMANAGER2209 -> imc (ok)
├── XCELIUM2209 -> xrun (ok) (22.09.s007 Base + last Hotfix)
└── XCELIUMML2209 -> xmml (ok)
/home/eda/synopsys
├── Installer
├── scl
│ └── 2022.12
├── vcs
│ └── T-2022.06-SP2 -> ok
├── vc_static
│ └── S-2021.09 -> ok
└── verdi
    └── T-2022.06 -> ok
Baidu Link Valid for Month
File shared via cloud drive: VER_VM2022
Link: https://pan.baidu.com/s/10Be-rXFu0Qu421zHfufkKA?pwd=hkan Extraction code: hkan
--Shared from Baidu Cloud Super VIP v1
Terabox link Valid for month (in terabox mobile app you can see ads & become premium very high download speed for pc app for a day or you can copy the file to your terabox drive)
https://1024terabox.com/s/1S2xWr1FkpcF90M9-RrQ6AA Extraction Code:y8u2
I have storage issues so I only opened the links for month but if any one can re-upload it and share it with better links, that would be great & we would be gratful
发表于 2025-11-28 11:46:25 | 显示全部楼层
thanks!
发表于 2025-11-28 11:55:56 | 显示全部楼层
thanks!
发表于 2025-11-28 11:57:36 | 显示全部楼层
good man
发表于 2025-11-28 12:33:48 | 显示全部楼层
duoxie
发表于 2025-11-28 12:52:38 | 显示全部楼层
Thanks
发表于 2025-11-28 13:18:19 | 显示全部楼层
Thank you
发表于 2025-11-28 13:19:43 | 显示全部楼层
多谢。
发表于 2025-11-28 13:46:25 | 显示全部楼层
goooooood
发表于 2025-11-28 14:40:08 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-25 22:47 , Processed in 0.216361 second(s), 5 queries , Gzip On, Redis On.
