查看: 357|回复: 1
[求助] 瞬态仿真收敛问题
发表于 2025-11-23 11:29:30 | 显示全部楼层 |阅读模式
ERROR (SPECTRE-16927): Transient simulation reaches maximum allowed number of convergence failures below minstep within 5% of stop time.
        Change option `max_minstep_nonconv' to adjust the allowed maximum number of convergence failures below minstep.
瞬态仿真遇到这样的问题,我这边已经在Options->Analog ->Miscellaneous tab ->
Additional Arguments -> max_minstep_nonconv=500添加了如上的指令,还是报这样的错,然后我的仿真设置是APS  同时开启了++aps,1.6ms的瞬态停止时间同时仿真设置为conservative
 楼主| 发表于 2025-11-23 11:30:17 | 显示全部楼层
顶顶顶顶顶顶
GMT+8, 2025-12-16 16:43 , Processed in 0.013694 second(s), 3 queries , Gzip On, Redis On.
