查看: 558|回复: 8
Sentaurus W-2024.09安装求助
发表于 2025-11-11 11:42:16 | 显示全部楼层 |阅读模式
虚拟机centos7.9,安装Sentaurus W-2024.09,运行SWB出现以下错误:
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libc.so.6: version `GLIBC_2.25' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libc.so.6: version `GLIBC_2.27' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libc.so.6: version `GLIBC_2.22' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libm.so.6: version `GLIBC_2.27' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/lib/libsimtree.so)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libc.so.6: version `GLIBC_2.25' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/lib/libsimtree.so)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libc.so.6: version `GLIBC_2.25' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/lib/libstdc++.so.6)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/lib/libstdc++.so.6)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libc.so.6: version `GLIBC_2.25' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/lib/libgfortran.so.5)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libm.so.6: version `GLIBC_2.26' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/lib/libgfortran.so.5)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libm.so.6: version `GLIBC_2.27' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/lib/libgfortran.so.5)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libm.so.6: version `GLIBC_2.18' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/lib/libgfortran.so.5)
/opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/bin/swb: /lib64/libm.so.6: version `GLIBC_2.23' not found (required by /opt/sentaurus/W-2024.09/bin/../tcad/current/linux64/lib/libquadmath.so.0)
请教大神是哪里出问题了?
发表于 2025-11-11 12:22:56 | 显示全部楼层
升级系统, rockylinux810或者redhat810
发表于 2025-11-11 15:17:02 | 显示全部楼层
或者选择:  Sentaurus W-2024.09-SP* 的版本。
 楼主| 发表于 2025-11-11 18:08:34 | 显示全部楼层
确实换了centos8就没问题了,谢谢!2025版centos7.9是可以的,我以为2024也可以。
发表于 2025-11-11 21:50:49 | 显示全部楼层
自行编译升级GLIBC到2.28,或者换更高版本的系统
发表于 2025-11-12 08:30:30 | 显示全部楼层
thanks
发表于 2025-11-12 11:39:30 | 显示全部楼层
GLIBC版本底了
发表于 2025-11-14 09:47:52 | 显示全部楼层
thanks.
 楼主| 发表于 2025-11-14 15:38:01 | 显示全部楼层
自行编译glibc挺麻烦,还是直接使用8吧
GMT+8, 2025-12-24 12:40 , Processed in 0.020441 second(s), 4 queries , Gzip On, Redis On.
