查看: 295|回复: 1
[转贴] QPS Qimera 2.7.6 最新完美
发表于 2025-11-10 09:29:09 | 显示全部楼层 |阅读模式
Qimera is an easy to use yet most powerful sonar data processing application. Built using core QPS technologies, As well as QPS QINSy projects, Qimera supports the major raw sonar file formats and by working with the Dynamic Workflow it revolutionises the way data is handled and the operator experience when processing hydrographic data. How? Qimera intelligently and interactively guides the operator through the data processing stages, simplifying what traditionally has been a convoluted process. Utilising the latest computing technologies, the unique IO Balanced Multi-Core engine in Qimera is specifically designed to process sonar data as rapidly as possible.
Qimera 智能且交互式地指导操作员完成数据处理阶段,从而简化传统上一直令人费解的过程。利用最新的计算技术,奇美拉独特的IO均衡多核引擎专门设计用于尽可能快地处理声纳数据。 Qimera 还包含许多先进的工具,包括声速分析(折射),校准(补丁测试)和摆动测试(用于解决常见传感器安装/集成问题)。Qimera 通过智能地提示下一个必要的行动来监督一个经验不足的用户,通过测深处理阶段。Dynamic Workflow 独特地记住了对项目数据应用了哪些操作和设置,因此能够突出显示需要进一步处理操作才能完成工作流程的文件。
5_1_d4244d50db09f7e.jpg Qimera also contains a number of advanced tools including Sound Velocity Profiling (refraction), Calibration (Patch Test), and a Wobble Test (for troubleshooting common sensor installation/integration issues). Qimera supervises a less experienced user through the stages of bathymetry processing by intelligently prompting the next necessary action(s). The Dynamic Workflow uniquely remembers what actions and settings have been applied to the project data, and so is able to highlight files that need further processing actions in order to complete the workflow. Remember, Qimera is a completely new product! Qimera is first and foremost a software platform designed to be offered stand-alone, or that can also be part of a QPS suite of tools. Qimera has the flexibility to penetrate into many markets with a variety of workflows, and Qimera is feature rich, fast, accurate and easy to use resulting in a good value proposition. Furthermore, Qimera is built to be localized for regional (local language) flexibility and User experience. Yes, Qimera does leverage some existing QPS technology, but importantly it has been built from the ground up.
5_1_d4244d50db09f7e.jpg 新版支持db文件编辑  完美永久
最新
https://qps.nl/downloads/qimera/
Qimera 2.7.6 已准备就绪!
添加了将路线用作配置文件的功能。
修复了使用“按系统过滤”将过滤器应用于单个多波束系统时出现的问题。
修复了使用自动原始文件导入时只能选择第一个动态网格的问题。
添加了对 Surfer Binary GRD 7+ 的支持。
查看发行说明以获取更多信息!
联系1739083603@qq.com
发表于 2025-11-10 17:50:40 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-12-27 23:48 , Processed in 0.014913 second(s), 4 queries , Gzip On, Redis On.
