查看: 490|回复: 1
[求助] ICC2 check_lvs short 問題!!
发表于 2025-9-22 09:42:48 | 显示全部楼层 |阅读模式
悬赏200资产未解决
各位前辈们好,小弟目前正在ICC2中check_lvs,目前遇到的问题是会有IO pin2跟nets显示有short violation  (Pin2 其實是IO ports name)
我去做确认却没有看到shorts的情况发生,也有去看netlist是不是有定义错误问题,但目前看起来都没错
想请问前辈们能否给一些建议
Information: Detected short violation. Cell1: xmtp_vddrdy. Pin2: MTP_VDDRDY (Net: MTP_VDDRDY). BBox: (410.4190 63.9990)(469.4210 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq11. Pin2: MTP_DQ[11] (Net: MTP_DQ[11]). BBox: (2371.3290 63.9990)(2430.3310 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq10. Pin2: MTP_DQ[10] (Net: MTP_DQ[10]). BBox: (2268.1240 63.9990)(2327.1260 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq9. Pin2: MTP_DQ[9] (Net: MTP_DQ[9]). BBox: (2164.9190 63.9990)(2223.9210 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq8. Pin2: MTP_DQ[8] (Net: MTP_DQ[8]). BBox: (2061.7140 63.9990)(2120.7160 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_noerr. Pin2: MTP_NOERR (Net: MTP_NOERR). BBox: (1958.5090 63.9990)(2017.5110 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq7. Pin2: MTP_DQ[7] (Net: MTP_DQ[7]). BBox: (1855.3040 63.9990)(1914.3060 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq6. Pin2: MTP_DQ[6] (Net: MTP_DQ[6]). BBox: (1752.0990 63.9990)(1811.1010 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq5. Pin2: MTP_DQ[5] (Net: MTP_DQ[5]). BBox: (1648.8940 63.9990)(1707.8960 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq4. Pin2: MTP_DQ[4] (Net: MTP_DQ[4]). BBox: (1545.6890 63.9990)(1604.6910 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq3. Pin2: MTP_DQ[3] (Net: MTP_DQ[3]). BBox: (1442.4840 63.9990)(1501.4860 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq2. Pin2: MTP_DQ[2] (Net: MTP_DQ[2]). BBox: (1339.2790 63.9990)(1398.2810 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq1. Pin2: MTP_DQ[1] (Net: MTP_DQ[1]). BBox: (1236.0740 63.9990)(1295.0760 64.0010). Layer: MET3. (RT-586)
Information: Detected short violation. Cell1: xmtp_dq0. Pin2: MTP_DQ[0] (Net: MTP_DQ[0]). BBox: (1132.8690 63.9990)(1191.8710 64.0010). Layer: MET3. (RT-586)
发表于 昨天 17:22 | 显示全部楼层
楼主解决了吗 我也遇到类似情况
GMT+8, 2025-10-29 07:08 , Processed in 0.267448 second(s), 4 queries , Gzip On, Redis On.
