 有没有大佬知道vc_static中的aip怎么能够在vcs中使用呢,直接吃编译能过但是仿真的时候报错:Error-[DPI-DIFNF] DPI import function not found
 /synopsys/vc_static/V-2023.12-SP1/packages/aip/AXI_STREAM_AIP/src/snps_axi_stream_aip_logic.svp, 18
 The definition of DPI import function/task 'SLI_Authorize' does not exist.Please check the stated DPI import function/task is defined, and itsdefinition is either passed in a source file at compile-time, or provided ina shared library specified using the LRM Annex-J options at run-time.
