查看: 361|回复: 2
[讨论] What is technology node?
发表于 2025-9-3 13:05:42 | 显示全部楼层 |阅读模式
Who can define what is technology node,
1). many are pointing to minimum channel length of the transistor that can be fabricated, and
2). some are telling it is just a marketing term not related to any physical dimension.
what is the exact definition of technology node?
发表于 2025-9-3 14:53:45 | 显示全部楼层
Planar nodes (20nm or above) are slightly larger than min channel length, while finfet(22nm or below) or GAA nodes are for marketing names only.
发表于 2025-9-3 15:00:50 | 显示全部楼层
先进工艺都是2吧,以前都是1
GMT+8, 2025-10-20 03:22 , Processed in 0.021381 second(s), 3 queries , Gzip On, Redis On.
