楼主: TerraWilly
[Windows] Synopsys License Generator
发表于 2025-11-24 20:12:08 | 显示全部楼层
终于来更新版本啦
发表于 2025-11-24 21:31:08 | 显示全部楼层
很奇怪, 生成的license过了不了SSS检测。我用传统的scl_keygen没问题。
11/24/2025 21:27:26 (snpslmd) ------------------------------------------------------------------
  11/24/2025 21:27:26 (snpslmd) Checking the integrity of the license file...
  11/24/2025 21:27:26 (snpslmd) The SSS features are garbled.
  11/24/2025 21:27:26 (snpslmd) All revenue keys ("SN=RK:..." on feature line) have been excluded.
  21:27:34 (lmgrd) snpslmd exited with status 255 ()
  21:27:34 (lmgrd) Since this is an unknown status, license server
  21:27:34 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
  21:27:34 (lmgrd) REStarted snpslmd (internet tcp_port 41668 pid 62089)
  21:27:34 (snpslmd) FlexNet Licensing version v11.19.6.0 build 293152 x64_linux
  21:27:35 (snpslmd) Feature SSS superseded by SSS
  11/24/2025 21:27:36 (snpslmd) INFO: Pooling on VENDOR_STRING is Disabled (to enable, set SCL_POOL_VS=1)
  11/24/2025 21:27:36 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2024.06
  21:27:37 (snpslmd) Feature SSS superseded by SSS
  21:27:38 (snpslmd) Feature SSS superseded by SSS
  11/24/2025 21:27:39 (snpslmd) INFO: License sanity check enabled (360)
  11/24/2025 21:27:39 (snpslmd) INFO: File descriptor limit (soft, hard) for snpslmd: 1024, 4096
  11/24/2025 21:27:39 (snpslmd) INFO: TCP - tcp_keepalive_time - 300 | tcp_keepalive_intvl - 75 | tcp_keepalive_probes - 9 | tcp_fin_timeout - 30    | net.ipv4.tcp_max_syn_backlog=4096 | net.core.somaxconn=128
  11/24/2025 21:27:39 (snpslmd) INFO: Cloud detection enabled. 1
  21:27:39 (snpslmd) SLOG: Summary LOG statistics is enabled.
  21:27:39 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
  21:27:39 (snpslmd) SLOG: VM Status: 4
  21:27:39 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT5
  21:27:39 (snpslmd) SLOG: TPM Status: 0
  21:27:39 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT6
  21:27:39 (snpslmd) CVD License file has been Tampered.So no.of license Restricted to Original count
  21:27:40 (snpslmd) CVD License file has been Tampered.So no.of license Restricted to Original count
发表于 2025-11-24 21:46:44 | 显示全部楼层
生成的licene, SSS 检测失败。The SSS features are garbled.
21:41:33 (lmgrd) (@lmgrd-SLOG@) Listening port: 27080
  21:41:33 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
  21:41:33 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
  21:41:33 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c synopsys.lic -l d.log
  21:41:33 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  synopsys.lic
  21:41:33 (lmgrd) (@lmgrd-SLOG@) ===============================================
  21:41:33 (lmgrd) Starting vendor daemons ...
  21:41:33 (lmgrd) Started snpslmd (internet tcp_port 50141 pid 76727)
  21:41:33 (snpslmd) FlexNet Licensing version v11.19.7.0 build 294770 x64_linux
  21:41:34 (snpslmd) Feature SSS superseded by SSS
  11/24/2025 21:41:35 (snpslmd) INFO: Pooling on VENDOR_STRING is Disabled (to enable, set SCL_POOL_VS=1)
  11/24/2025 21:41:35 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2025.03
  21:41:36 (snpslmd) Feature SSS superseded by SSS
  21:41:38 (snpslmd) Feature SSS superseded by SSS
  11/24/2025 21:41:39 (snpslmd) INFO: License sanity check enabled (360)
  11/24/2025 21:41:39 (snpslmd) INFO: File descriptor limit (soft, hard) for snpslmd: 1024, 4096
  11/24/2025 21:41:39 (snpslmd) INFO: TCP - tcp_keepalive_time - 300 | tcp_keepalive_intvl - 75 | tcp_keepalive_probes - 9 | tcp_fin_timeout - 30    | net.ipv4.tcp_max_syn_backlog=4096 | net.core.somaxconn=128
  11/24/2025 21:41:39 (snpslmd) INFO: Cloud detection enabled. 1
  21:41:39 (snpslmd) SLOG: Summary LOG statistics is enabled.
  21:41:39 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
  21:41:39 (snpslmd) SLOG: VM Status: 4
  21:41:39 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT5
  21:41:39 (snpslmd) SLOG: TPM Status: 0
  21:41:39 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT6
  21:41:39 (snpslmd) CVD License file has been Tampered.So no.of license Restricted to Original count
  21:41:46 (snpslmd) vmm_sata_mon vpg     vrtcli
  21:41:46 (snpslmd) vsecP_OEM_VCS_FUJITSU_RUN_NW vti     wanr_certify_global
  21:41:46 (snpslmd) wanr_certifymapper_global wanr_synplify_global wanr_synplifypremier_global
  21:41:46 (snpslmd) wanr_synplifypremierdp_global wanr_synplifypro_global wdf2pwl
  21:41:46 (snpslmd) wdf2tbl      wglpatt     xTractor
  21:41:46 (snpslmd) xltt
  21:41:46 (snpslmd)
  21:41:46 (snpslmd) Licenses are case sensitive for TE_CATS
  21:41:46 (snpslmd)
  21:41:46 (snpslmd) EXTERNAL FILTERS are OFF
  21:41:46 (lmgrd) snpslmd using TCP-port 50141
  21:41:46 (snpslmd) Serving features for the following vendor names:
   snpslmd  ACAD  adalmd  anagram  arcd  atrenta  avantd  CADABRA  chrysalisd  cowared  doradod  EPIC  eved  extremed  fishtail  hscd  imperasd      innologd  ISE-TCADd  knights  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  piketec  riod  saber_dmn  sandwork  sclmgrd    sftlmd  sigmacd  SIINT  simple  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  VALTRIXT  vastlmd  vcsd       wlld
  11/24/2025 21:41:49 (snpslmd) ------------------------------------------------------------------
  11/24/2025 21:41:49 (snpslmd) Checking the integrity of the license file...
  11/24/2025 21:41:49 (snpslmd) The SSS features are garbled.
  11/24/2025 21:41:49 (snpslmd) All revenue keys ("SN=RK:..." on feature line) have been excluded.
  21:41:57 (lmgrd) snpslmd exited with status 255 ()
  21:41:57 (lmgrd) Since this is an unknown status, license server
  21:41:57 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
  21:41:57 (lmgrd) REStarted snpslmd (internet tcp_port 52304 pid 77088)
  21:41:57 (snpslmd) FlexNet Licensing version v11.19.7.0 build 294770 x64_linux
  21:41:58 (snpslmd) Feature SSS superseded by SSS
  11/24/2025 21:41:58 (snpslmd) INFO: Pooling on VENDOR_STRING is Disabled (to enable, set SCL_POOL_VS=1)
  11/24/2025 21:41:58 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2025.03
  21:41:59 (snpslmd) Feature SSS superseded by SSS
  21:42:01 (snpslmd) Feature SSS superseded by SSS
  11/24/2025 21:42:02 (snpslmd) INFO: License sanity check enabled (360)
  11/24/2025 21:42:02 (snpslmd) INFO: File descriptor limit (soft, hard) for snpslmd: 1024, 4096
  11/24/2025 21:42:02 (snpslmd) INFO: TCP - tcp_keepalive_time - 300 | tcp_keepalive_intvl - 75 | tcp_keepalive_probes - 9 | tcp_fin_timeout - 30    | net.ipv4.tcp_max_syn_backlog=4096 | net.core.somaxconn=128
发表于 2025-11-24 23:37:12 | 显示全部楼层
看看
发表于 2025-11-25 10:30:04 | 显示全部楼层
thanks!!
发表于 2025-11-25 11:36:18 | 显示全部楼层
keyi可以
发表于 2025-11-25 15:12:13 | 显示全部楼层
感谢大神
发表于 2025-11-25 16:19:51 | 显示全部楼层
大大大大thanks
发表于 2025-11-25 16:33:36 | 显示全部楼层
感谢大佬
发表于 2025-11-25 19:40:21 | 显示全部楼层
Thanks for sharing.
GMT+8, 2025-12-30 04:33 , Processed in 0.019969 second(s), 4 queries , Gzip On, Redis On.
