查看: 3011|回复: 9
A Dual-Path Three-Stage VCO with Wide Tuning Range
发表于 2008-3-6 14:00:53 | 显示全部楼层 |阅读模式
A Dual-Path Three-Stage VCO with Wide Tuning Range.pdf (96.48 KB , 下载次数: 60 ) 发篇文章,挣点钱
Abstract:In this paper, a full integrated high-speed ring VCO is designed. The VCO consists of three stages, each of which is composed of a fast path and a slow path while the outputs of both paths are summed. Since the 0.25um CMOS technology and 3.3v voltage supply, the VCO has a wide operating frequency ranging from 800MHz to 2.1GHz with a high gain of 1.08GHz/V. PLL and frequency synthesizer will be the potential applications.
[ 本帖最后由 nicole528 于 2008-3-6 15:49 编辑 ]
发表于 2008-3-6 21:38:48 | 显示全部楼层
是个骗子!
发表于 2008-3-6 22:34:21 | 显示全部楼层
看看看看看
发表于 2008-3-6 22:36:22 | 显示全部楼层
呵呵,上海大学的国货
发表于 2008-3-10 11:50:29 | 显示全部楼层
kan kan
kan kan
发表于 2009-12-1 14:59:41 | 显示全部楼层
rubbish!!!!!
发表于 2009-12-1 16:18:36 | 显示全部楼层
thanks for sharing
发表于 2010-8-9 13:16:23 | 显示全部楼层
xiexie xiexie
发表于 2011-2-14 05:46:11 | 显示全部楼层
正好需要 谢谢了
发表于 2013-3-19 19:34:00 | 显示全部楼层
大家有所帮助
GMT+8, 2025-12-15 06:06 , Processed in 0.028674 second(s), 8 queries , Gzip On, Redis On.
