查看: 805|回复: 3
[求助] redhat7.9的镜像文件失败,提示看不懂,请大家帮看看
发表于 2025-6-15 13:57:52 | 显示全部楼层 |阅读模式
挂载一个redhat7.9的镜像文件,挂在命令为mount -o loop /home/tools/iso/rhel-server-7.9-x86_64-dvd.iso /mnt/ISO/
提示mount: wrong fs type, bad option, bad superblock on /dev/loop0,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail or so.
然后我查看了 dmesg | tail ,提示完全看不懂
[  200.571633] sd 13:0:0:0: [sdb] No Caching mode page found
[  200.571635] sd 13:0:0:0: [sdb] Assuming drive cache: write through
[  200.576720]  sdb: sdb4
[  200.579808] sd 13:0:0:0: [sdb] Attached SCSI removable disk
[  200.792673]  sdb: sdb4
[  569.050371] loop: module loaded
[  894.735714] tg3 0000:01:00.0 em1: Link is up at 1000 Mbps, full duplex
[  894.735721] tg3 0000:01:00.0 em1: Flow control is off for TX and off for RX
[  894.735723] tg3 0000:01:00.0 em1: EEE is disabled
[  894.735735] IPv6: ADDRCONF(NETDEV_CHANGE): em1: link becomes ready
换一个镜像文件能够挂载成功,请问各位是什么情况?
发表于 2025-6-15 16:27:02 | 显示全部楼层
看看是不是这个镜像文件下载有问题,最可靠的检查代码是检查md5sum,简单点是在Windows下能查看里面的内容么?
发表于 2025-6-15 16:43:48 | 显示全部楼层
make sure iso file is not corrupted and try again with option '-t iso9660'
 楼主| 发表于 2025-6-16 08:49:14 | 显示全部楼层
file -t iso9660?
GMT+8, 2025-12-27 04:24 , Processed in 0.051014 second(s), 3 queries , Gzip On, Redis On.
