查看: 991|回复: 5
[求助] VCS2023安装问题
发表于 2025-6-13 21:15:36 | 显示全部楼层 |阅读模式
安装完成之后,使用vcs时,报错如下:
[SCL] Error:  One possible reason for this error is that FLEXlm version of the application is higher than the license daemon version. If this is the case, please upgrade the license daemon to latest version (SCL-602)
Fatal License Error.
Internal FLEXlm Error.
Please contact VCS Customer Support at 1-800-VERILOG for more information.
/home/yue/synopsys_apps/vcs/V-2023.12-SP2/bin/vcs: line 6029: dc: command not found
有大佬知道怎么解决吗?
发表于 2025-6-13 23:20:30 | 显示全部楼层
scl-602 means you need newer scl
 楼主| 发表于 2025-6-14 09:14:57 | 显示全部楼层
大佬有scl2023的文件吗
发表于 2025-6-14 10:45:24 | 显示全部楼层
 楼主| 发表于 2025-6-14 11:21:39 | 显示全部楼层
taiakun 发表于 2025-6-14 10:45
https://bbs.eetop.cn/forum.php?mod=redirect&goto=findpost&ptid=990768&pid=11485605
但是这个文件中只有:
snpslmd
scl_v2023.09_common.spf
scl_v2023.09_linux64.spf
这三个文件,和安装包自带的scl2021的文件内容不一样,即使是解压之后:
scl
├── 2021.03
│   ├── linux64
│   │   ├── drivers
│   │   │   ├── sntl-sud-7.5.2-0.i386.rpm
│   │   │   ├── WkRt-Lin-6.51.3477-500.x86_64.rpm
│   │   │   ├── wkrt-lin_6.51.3477.500_amd64.deb
│   │   │   ├── libhasp_linux_x86_64.so
│   │   │   ├── aksusbd-7.101-1.x86_64.rpm
│   │   ├── bin
│   │   │   ├── FNPLicensingService
│   │   │   │   ├── FNPLicensingService
│   │   │   ├── sclsort
│   │   │   ├── whatscl
│   │   │   ├── watchlog
│   │   │   ├── ssdm_admin
│   │   │   ├── sssverify
│   │   │   ├── sshostid
│   │   │   ├── ssdm_collect
│   │   │   ├── lmdown
│   │   │   ├── lmgrd
│   │   │   ├── lmreread
│   │   │   ├── lmutil
│   │   │   ├── lmhostid
│   │   │   ├── README.TXT
│   │   │   ├── lmstat
│   │   │   ├── server_debug_conf.xml
│   │   │   ├── config.xml
│   │   │   ├── lmdiag
│   │   │   ├── snpslmd
│   │   │   ├── install_fnp.sh
│   │   │   ├── lmver
│   │   │   ├── sclsh
│   ├── Synopsys.dat
您知道怎么做吗?
发表于 2025-7-27 15:10:07 | 显示全部楼层
liangy001 发表于 2025-6-14 11:21
但是这个文件中只有:
snpslmd
楼主你解决这个问题了吗?
GMT+8, 2025-10-18 13:22 , Processed in 0.014618 second(s), 4 queries , Gzip On, Redis On.
