查看: 1138|回复: 7
[求助] EXT151打开报错
发表于 2025-5-29 20:42:42 | 显示全部楼层 |阅读模式
在终端内读取.bashrc文件后,在终端内输入qrc &,跳出如下报错:
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaDesign.so)
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaPlugIn.so)
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaTech.so)
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaDM.so)
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaDM.so)
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaBase.so)
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaBase.so)
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaCommon.so)
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaCommon.so)
/opt/eda/cadence/EXT151/tools.lnx86/extraction/bin/64bit/qrc: /opt/eda/cadence/EXT151/tools.lnx86/lib/64bit/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/eda/cadence/EXT151/share/oa/lib/linux_rhel60_64/opt/liboaWafer.so)
但是相关的库文件在运行前通过rpm安装好了,要怎么解决呢
EXT151报错内容
EXT151报错内容
环境变量相关内容
环境变量相关内容
发表于 2025-5-29 21:07:22 | 显示全部楼层
系统用的哪个?是不是高了或者底了
发表于 2025-5-29 21:08:53 | 显示全部楼层
Cadence的工具,checkSys要过的。执行看看。缺什么rpm
 楼主| 发表于 2025-5-29 22:34:05 | 显示全部楼层
Lover_Momo 发表于 2025-5-29 21:07
系统用的哪个?是不是高了或者底了
CentOS7
发表于 2025-5-30 07:26:01 | 显示全部楼层
看一下这个。checkSysConf,如果有报FAIL的,安装一下。
发表于 2025-5-30 07:33:09 | 显示全部楼层
你的OA,是不是在安装的时候,被设置成了更高版本的呢?
或者是,起Tool的时候,吃到了更高版本的Tool,然后OA也设置成了更高版本的,导致qrc起的时候报错。
我猜测正常的ETX151的CXXABI的版本是1.3。但是你的OA 版本需要1.3.9了。
 楼主| 发表于 2025-6-4 23:27:18 | 显示全部楼层
或者是,起Tool的时候,吃到了更高版本的Tool,然 ...
是的是的,非常感谢。
因为配的是IC618,OA就_60版本的了,重新设置了一下OA这个报错就没了,但是遇到了新的,我在论坛里也有看到,然后出现了下面的这个情况。
ERROR (EXTQRCXLOG-115) :  A command file and design data inputs are required for this QRC session to
proceed.  Type -u or -h for more information on running QRC.
ERROR (EXTQRCXLOG-113) : This QRC session could not continue due to previous errors.
论坛里的哪一个帖子给出的方案是
将export QRC_MOS_LW_PRECISION=Y这一段代码给注释掉,但是我这边注释了没有效果,然后就是在layout界面里没有看到QRC的菜单栏,大佬有没有解决方案啊
发表于 2025-11-11 19:20:23 | 显示全部楼层
Heretica 发表于 2025-6-4 23:27
是的是的,非常感谢。
因为配的是IC618,OA就_60版本的了,重新设置了一下OA这个报错就没了,但是遇到了 ...
我OA改完后现在问题和你一样,请问你后面解决了吗
GMT+8, 2025-12-15 23:24 , Processed in 0.153068 second(s), 5 queries , Gzip On, Redis On.
