楼主: spike_1110
[求助] 关于在agent中例化多个sqr,drv中例化多个seq_item_port,seq传输出错问题的求助
 楼主| 发表于 2025-5-27 16:53:38 | 显示全部楼层
已解决,cfg配置问题。由于在环境中例化了两个agent,agent[0]为master模式,agent[1]为slave,slave模式的agent没有drv,因此连接会出错,加上相应的条件既可,同时可以加一些debug信息,如下:
function void axi_agent::connect_phase(uvm_phase phase);
    super.connect_phase(phase);
    if (m_drv == null && drv_sw == sail_dec::ON)
        `uvm_fatal("DRV_NULL", "Driver is not created")
    if (r_sqr == null)
        `uvm_fatal("SQR0_NULL", "Sequencer read is not created")
    //for read sequencer
    if(work_mode == sail_dec::MASTER)
        m_drv.seq_item_port2.connect(r_sqr.seq_item_export);
endfunction
回复 支持 2 反对 0
GMT+8, 2025-10-19 10:12 , Processed in 0.059437 second(s), 4 queries , Gzip On, Redis On.
