查看: 3273|回复: 30
[资料] Cadence RAK : Custom IC Design Flow Methodology
发表于 2025-5-19 15:25:13 | 显示全部楼层 |阅读模式
Design Methodology Concepts
In this proposed “Custom IC Design Flow/Methodology”, you will be using the Concurrent Design Methodology approach.
− Top-level and low-level designs start simultaneously and proceed concurrently.
− Top-level design begins with high-level, abstract descriptions of the circuits; low-level design is performed at the transistor level (lowest abstraction level).
− The design implementation progresses and is completed through a blend of Top-Down and Bottom-Up design tasks.
− The high-abstraction-level views of blocks are incrementally replaced with the more accurate transistor-level views, as they become available from the block designers.
RAK File:https://www.mediafire.com/file/5 ... gn_Flow.tar.gz/file
我的百度盘没空间了,只能用这个分享了
Custom IC Design Flow Methodology - Stage0 RAK Introduction.pdf
436.11 KB, 下载次数: 204 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Custom IC Design Flow Methodology - Stage1 Schematic Capture & Circuit Simulation.pdf
14.6 MB, 下载次数: 222 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Custom IC Design Flow Methodology - Stage2 Circuit Layout.pdf
11.51 MB, 下载次数: 212 , 下载积分: 资产 -4 信元, 下载支出 4 信元
Custom IC Design Flow Methodology - Stage3 Circuit Physical Verification and Par.pdf
6.13 MB, 下载次数: 220 , 下载积分: 资产 -3 信元, 下载支出 3 信元
Custom IC Design Flow Methodology - Stage4 Post-Layout Circuit Simulation.pdf
9.62 MB, 下载次数: 212 , 下载积分: 资产 -4 信元, 下载支出 4 信元
Custom IC Design Flow Methodology - Stage5 GDSII Generation.pdf
543.31 KB, 下载次数: 214 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2025-5-19 16:08:41 | 显示全部楼层
Thanks for sharing
发表于 2025-5-19 16:35:32 | 显示全部楼层
thanks
发表于 2025-5-19 18:34:35 | 显示全部楼层
谢谢
发表于 2025-5-19 20:06:14 | 显示全部楼层
感谢分享
发表于 2025-5-19 21:36:13 | 显示全部楼层
GOOOOOOOOOOOOOOOOOOOD
发表于 2025-5-20 06:56:22 | 显示全部楼层
Good!
发表于 2025-5-20 07:31:49 | 显示全部楼层
多谢分享
发表于 2025-5-20 08:17:24 | 显示全部楼层
感谢楼主分享
发表于 2025-5-20 10:48:52 | 显示全部楼层
3q for share~
GMT+8, 2025-11-4 21:38 , Processed in 0.291206 second(s), 4 queries , Gzip On, Redis On.
