查看: 911|回复: 1
[原创] PR-MILKYWAY-GDS做库
发表于 2025-5-14 16:42:35 | 显示全部楼层 |阅读模式
因为用ICC比较多,后续的介绍以ICC为主。本节介绍ICC的做库工具MILKWAY
MILKWAY做库通常可以由gds、lef等,这里介绍GDS做库
通过GDS做库,适用于定制的标准单元,或者手动定制的ip
1. MILKWAYgui->cell library->library preparation
2.Read library gui->library name(saed32)->preparephysical library
3. prepare physical library gui->checklibrary->library name
4. prepare physical library gui->TF+GDS+CLF
5.create library gui->library name(saed32)->TF(saed32.tf)
6.Set bus name style gui->library name(saed32)->style
7.stream in gui -> stream file name(xxx.gds)->libraryname(saed32)->cell type definition file(gds2Arcs.map)->layer file(tf2gds.map,onlyextract layer option)
8.smash –gui->OK
9.set cell port type –gui->load scheme filelibrary(scheme.clf)
10.extract bpv –gui -> extract blockage(polyMn)-> extract pin by text ->extract via
11.set pr boundary -> left boundary ->tile width -> height
12.update_mw_port_by_db –mw_lib saed32.db –db_file{xxx/xxx}
13.export->lef
检查单元/ip lef是否提取合理,至此完成简单gds做库
发表于 2025-5-15 08:53:48 | 显示全部楼层
#在这MILKYWAY里快速回复#
GMT+8, 2025-12-25 15:43 , Processed in 0.014698 second(s), 4 queries , Gzip On, Redis On.
