查看: 920|回复: 0
[求助] cadence617器件多时仿真噪声报错FATAL (SPECTRE-20): Illegal instruction.
发表于 2025-5-14 09:11:40 | 显示全部楼层 |阅读模式
悬赏50资产未解决
Cadence 617运行仿真时,只要器件多到超过某个阈值,仿真设置勾选跟Noise相关的选项例如sp里面的 Do Noise,或者仿真pnoise,hbnoise都会报错,报错就只有
Internal error found in spectre at freq = 10 GHz during SP analysis `sp'.
Encountered a critical error during simulation. Submit a Service Request via Cadence Online Support, including the netlist, the Spectre log file, the behavioral model files, and any other information that can help identify the problem.
这几行信息,要是只仿真单个管子或者几个小电路就没事,可以正常仿真。
是cadence软件问题呢还是系统的问题呢,cadence617软件和工艺库是从别的地方复制过来的,系统是centos7
报错信息
报错信息
GMT+8, 2025-12-22 02:54 , Processed in 0.012173 second(s), 4 queries , Gzip On, Redis On.
