查看: 757|回复: 3
[求助] LVS报错
发表于 2025-5-5 14:58:38 | 显示全部楼层 |阅读模式
CELL COMPARISON RESULTS ( TOP LEVEL )
                   #           #     NOT COMPARED     #
  Error:    Different numbers of ports (see below).
  Error:    Ground net missing in layout.
LAYOUT CELL NAME:         mash111_top
SOURCE CELL NAME:         mash111_top
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              5        83    *
Nets:            6009      7734    *
Instances:       6941      6941         MN (4 pins)
                  6941      6941         MP (4 pins)
Total Inst:     13882     13882
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              5        83    *
Nets:            4439      6122    *
Instances:       4977      5017    *    MN (4 pins)
                  5513      5607    *    MP (4 pins)
                     0       110    *    SDW2 (3 pins)
                     0        33    *    SDW3 (4 pins)
                     0         2    *    SPDW_2_1 (4 pins)
                   683       567    *    SMN2 (4 pins)
                   176       143    *    SMN3 (5 pins)
                   308       293    *    SMP2 (4 pins)
                     8        12    *    SPMN_2_1 (5 pins)
                   197       188    *    SPMP_2_1 (5 pins)
                    22        46    *    SPMP_2_2 (6 pins)
Total Inst:     11884     12018
       * = Number of objects in layout different from number in source.
                               INFORMATION AND WARNINGS
o Statistics:
   66 source nets were deep shorted to 33.
   320 layout mos transistors were reduced to 141.
     179 mos transistors were deleted by parallel reduction.
   8 source nets had all their pins removed and were deleted.
请问跑LVS的时候,出现的这个两个错误,怎么解决
发表于 2025-5-5 15:50:22 | 显示全部楼层
你版图port没打全啊
 楼主| 发表于 2025-5-6 13:22:41 | 显示全部楼层
fengrlove 发表于 2025-5-5 15:50
你版图port没打全啊
具体该怎么做啊?可以简述下流程不
发表于 2025-5-6 14:03:43 | 显示全部楼层
数字版图stream out之前要给pin打text吧,否则calibre识别不到pin。下面是脚本
set_write_stream_options -output_pin text
set_write_stream_options -output_pin geometry
foreach_in_collection PORT_NAME $ALL_PORTS {
    set xy_location [get_location $PORT_NAME]
    set x_location  [lindex $xy_location 0]
    set y_location  [lindex $xy_location 1]
    set TEXT_NAME [collection_to_list $PORT_NAME]
    set TEXT_NAME_1 [string range $TEXT_NAME 7 end-2]
    create_text -origin [list [expr $x_location] [expr $y_location]] \
                -height 1 \
                -layer 85 \
                -orient W $TEXT_NAME_1
可以根据自己的text金属层number改一下。模拟版图的话应该是virtuoso里面打label吧,刚学后端不知道对不对,可以试试。
GMT+8, 2025-12-26 05:35 , Processed in 0.017304 second(s), 4 queries , Gzip On, Redis On.
