查看: 690|回复: 1
[求助] qrc提取spef过程中报的error,如何分析?map也进行了检查没有什么问题,
发表于 2025-4-18 09:13:44 | 显示全部楼层 |阅读模式
WARNING (EXTGRMP-546) : Macro FILL4_12TV50 is incomplete because layer M1 is not defined in the technology file. Please check its definition.
WARNING (EXTGRMP-546) : Macro FILL6_12TV50 is incomplete because layer M1 is not defined in the technology file. Please check its definition.
WARNING (EXTGRMP-546) : Macro FILL2_12TV50 is incomplete because layer M1 is not defined in the technology file. Please check its definition.
WARNING (EXTGRMP-546) : Macro FILL1_12TV50 is incomplete because layer M1 is not defined in the technology file. Please check its definition.
WARNING (EXTGRMP-546) : Macro FILL8_12TV50 is incomplete because layer M1 is not defined in the technology file. Please check its definition.
WARNING (EXTGRMP-546) : Macro FCAP2_12TV50 is incomplete because layer M1 is not defined in the technology file. Please check its definition.
WARNING (EXTGRMP-546) : Macro FCAP12_12TV50 is incomplete because layer M1 is not defined in the technology file. Please check its definition.
WARNING (EXTGRMP-546) : Macro FCAP6_12TV50 is incomplete because layer M1 is not defined in the technology file. Please check its definition.
INFO (EXTGRMP-195) : Reading PINS section.
ERROR (EXTSNZ-127) : The layer name "M2" is used in the LEF/DEF file or in the OpenAccess (OA) database but the definition for it cannot be found in the tech file.  Ensure that the command file has a proper name mapping for the tech file layer to corresponding names in LEF/cellLibrary/DEF/OA. Refer to the user manual for command syntax.
ERROR (EXTQRCXLOG-110) : Exiting due to an internal error
使用map格式如下
NAME                   M1/PIN            141                       0
NAME                   M2/PIN            142                       0
NAME                   TM2/PIN            122                       3
NAME                   M1/SPNET            141                0
NAME                   M2/SPNET            142                0
NAME                   TM2/SPNET            122                3
NAME               M1/LEFPIN        141                0
NAME               M2/LEFPIN        142                0
NAME               TM2/LEFPIN       122                3
M1                   NET                    61                       0
M1                   VIA                    61                       0
M1                   SPNET            61                       0
M1                   PIN                    61                       0
M1                   FILL                    61                       1
M1                   LEFPIN            61                       0
M1                   LEFOBS            61                       0
V1                   VIA                    70                       0
M2                   NET                    62                       0
...........等等
发表于 2025-4-18 09:39:52 | 显示全部楼层
学习到了
GMT+8, 2025-12-14 10:47 , Processed in 0.013470 second(s), 4 queries , Gzip On, Redis On.
