查看: 1031|回复: 7
【求助】在VC$2409上跑一个UVM的demo,跑起来不正常,求助
发表于 2025-4-13 16:03:07 | 显示全部楼层 |阅读模式
在VCS上跑一个UVM的小样例程序,用的是uvm-2020.2.2,可以正常跑起来,但是明显跑起来的是有问题的。仿真只停留在0时刻就退出了。
请指点迷津,多谢多谢!
MakeFile:
all: clean comp run
clean:
        rm -rf ./simv* ./csrc ./*.log ./vc_hdrs.h ./ucli.key
comp:
        vcs -full64 -sverilog -timescale=1ns/1ns -ntb_opts uvm-ieee-2020-2.0 +incdir+. simple.sv -l comp.log
run:
        ./simv  +UVM_NO_RELNOTES  -l run.log
UVM demo: simple.sv
`timescale 1ns/1ns
module test;
  import uvm_pkg::*;
  `include "uvm_macros.svh"
  const uvm_test_done_objection total_test_done = uvm_test_done_objection::get();
  class simple_test extends uvm_test;
    function new (string name, uvm_component parent);
      super.new(name, parent);
    endfunction : new
    `uvm_component_utils(simple_test)
    virtual task run_phase(uvm_phase phase);
      uvm_report_info("drain", "Setting drain time of 30", UVM_NONE);
      total_test_done.set_drain_time(this,30);
      fork
        doit(35);
        doit(25);
        doit(50);
        doit(15);
      join
          uvm_report_info("[run_phase]", "run_phase endded...", UVM_NONE);
    endtask
    task doit (time delay);
      static int s_inst = 0; int inst = s_inst++;
      total_test_done.raise_objection(this);
      uvm_report_info("doit", $sformatf("Starting doit (%0d) with delay %0t", inst, delay), UVM_NONE);
      #delay;
      uvm_report_info("doit", $sformatf("Ending doit (%0d)", inst), UVM_NONE);
      total_test_done.drop_objection(this);
    endtask
    virtual function void dropped (uvm_objection objection,
        uvm_object source_obj, string description, int count);
      uvm_report_info("dropped",
        $sformatf("%d objection(s) dropped from %s, total count is now %0d", count, source_obj.get_full_name, objection.get_objection_total(this)), UVM_NONE);
    endfunction
  endclass : simple_test
  initial
    run_test("simple_test");
endmodule
正常情况下,“Ending doit”会打印出来。但是我跑起来一直没有,仿真时间没有往前走就退出了。
demo里面应该需要改一下吧?
没搞明白,请牛人指点一下吧
发表于 2025-4-13 20:48:15 | 显示全部楼层
牛人应该会叫你先把安装包拿出来
我没骗你吧!
发表于 2025-4-13 21:37:06 | 显示全部楼层
qiu安装包
发表于 2025-4-13 22:11:19 | 显示全部楼层
分享一下uvm-2020.2.2,我没帮你跑一下
 楼主| 发表于 2025-4-14 07:36:32 | 显示全部楼层
这是两个版本的uvm library,如果不用工具自带的库,效果也是一样。看起来跟工具没关系,demo里面应该需要改动一下。不知道怎么改?
UVM-1800.2-2020.2.0.tar.gz
658.09 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
UVM-1800.2-2020.3.1.tar.gz
707.23 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2025-4-14 07:46:13 | 显示全部楼层
andrew_7134 发表于 2025-4-13 20:48
牛人应该会叫你先把安装包拿出来
我没骗你吧!
这个现象跟工具版本没有太大关系,你拿论坛里面的23年版本的也一样是这个现象。那个demo里面应该是有问题。uvm-1.2的里面有类似的demo,但是那个在1.2上没问题。
发表于 2025-4-14 09:25:45 | 显示全部楼层
您好!把VC$2409分享一下,可以吗?
发表于 2025-4-14 10:23:57 | 显示全部楼层
牛人应该会叫你先把安装包拿出来
我没骗你吧!
预言家
GMT+8, 2025-12-30 04:21 , Processed in 0.022027 second(s), 5 queries , Gzip On, Redis On.
