查看: 12377|回复: 224
[资料] RAK : Using Liberate to Characterize Standard Cells
发表于 2025-4-7 20:32:57 | 显示全部楼层 |阅读模式
Digital libraries are used in ASIC design for synthesis, static timing analysis, and power estimation. The Liberty file format is a standard format supported by many tools, including Cadence’s Innovus, and sign-off tools like Cadence’s Tempus and Voltus. The Virtuoso Liberate Characterization tool is the accurate, efficient, and easy-to-use library characterizer to create the Liberty file for digital libraries. Liberate uses SPICE simulation, supported through Spectre, for capturing a cell model that is almost as accurate a SPICE, but does not require the CPU runtime of SPICE simulation on a full ASIC design. This Rapid Adoption Kit (RAK) gives a general overview of the syntax of Liberty (.lib) file, and how to to use Liberate to run characterization to generate the Liberty file. Last Tested Releases: Liberate 19.2.1
文档数据网络搜集而来,仅用作学习使用,请勿用作商业用途,侵删。
文档资料回复可见。
游客 ,如果您要查看本帖隐藏内容请回复
发表于 2025-4-7 21:06:30 | 显示全部楼层
谢谢分享
发表于 2025-4-7 21:09:09 | 显示全部楼层
谢谢分享
发表于 2025-4-7 21:16:53 | 显示全部楼层
感谢分享~~
发表于 2025-4-7 21:17:01 | 显示全部楼层
Thanks~
发表于 2025-4-7 21:19:46 | 显示全部楼层
good
发表于 2025-4-7 21:20:04 | 显示全部楼层
thanks for your sharing
发表于 2025-4-7 21:28:41 | 显示全部楼层
thanks
发表于 2025-4-7 21:28:50 | 显示全部楼层
谢谢分享
发表于 2025-4-7 21:55:45 | 显示全部楼层
666666666666
GMT+8, 2025-9-17 03:26 , Processed in 0.023044 second(s), 5 queries , Gzip On, Redis On.
