查看: 671|回复: 0
[求助] 仿真文件--复位信号拉高时的赋值问题
发表于 2025-4-6 22:26:35 | 显示全部楼层 |阅读模式
我设置的ext_clk_25m时钟信号,周期是40ns。
我在testbench中,不小心把ext_rst_n的初始化拉高在了时钟上升沿(100ns),发现delay的+1操作也能在此时赋值,这是为什么,不是应该延迟一拍吗?
代码:
  1. reg[23:0] delay;
  2. always @ (posedge ext_clk_25m or negedge ext_rst_n)
  3.         if(!ext_rst_n) delay <= 24'd0;
  4.         else delay <= delay+1'b1;
    复制代码
仿真文件:
  1. `timescale 1 ns/ 1 ps
  2. module cy4_vlg_tst();
  3. // constants
  4. // general purpose registers
  5. //reg eachvec;
  6. // test vector input registers
  7. reg ext_clk_25m;
  8. reg ext_rst_n;
  9. reg [1:0] key_v;
  10. reg [0:0] switch;
  11. // wires
  12. wire [7:0]  led;
  13. // assign statements (if any)
  14. cy4 i1 (
  15. // port map - connection between master ports and signals/registers
  16.         .ext_clk_25m(ext_clk_25m),
  17.         .ext_rst_n(ext_rst_n),
  18.         .key_v(key_v),
  19.         .led(led),
  20.         .switch(switch)
  21. );
  22. initial
  23. begin
  24. // code that executes only once
  25. // insert code here --> begin
  26. ext_clk_25m = 0;
  27. ext_rst_n =0;
  28. switch =1;
  29. key_v = 2'b11;
  30. // delay 100ns, wait the finish of ststem reset
  31. # 100;
  32. ext_rst_n = 1;
  33. # 20;
  34. key_v = 2'b01;
  35. switch = 0;
  36. # 120;
  37. key_v = 4'b11;//little bounce
  38. # 10;
  39. key_v = 4'b01;
  40. # 40000160;
  41. # 167772120;
  42. $stop;
  43. // --> end
  44. $display("Running testbench");
  45. end
  46. always #20 ext_clk_25m = ~ext_clk_25m;        //generate 25MHz clock  source
  47.
  48. endmodule
  49.
    复制代码
GMT+8, 2025-11-16 15:50 , Processed in 0.014976 second(s), 4 queries , Gzip On, Redis On.
