查看: 898|回复: 3
[求助] 工艺角仿真问题
发表于 2025-4-6 09:53:03 | 显示全部楼层 |阅读模式
仿真工艺角时对于电阻等元件没有sf和fs工艺角,那么在仿真sf、fs工艺角时电阻该怎么给呢。从哪里找到说明呢
发表于 2025-4-6 13:54:09 | 显示全部楼层
no fs and sf cases for resistors, only tt, ss and ff
 楼主| 发表于 2025-4-11 11:13:38 | 显示全部楼层
thank you!Since resistors do not have SF and FS process corners, when we conduct simulations for SF or FS process corners separately, which process corner should be chosen for resistors, transistors and capacitors?
发表于 5 天前 | 显示全部楼层
镍铬合金丝 发表于 2025-4-11 11:13
thank you!Since resistors do not have SF and FS process corners, when we conduct simulations for S ...
typical
GMT+8, 2025-10-22 12:41 , Processed in 0.014203 second(s), 4 queries , Gzip On, Redis On.
