查看: 1261|回复: 4
[讨论] finfet IC Yield会很高吗 ?
发表于 2025-3-19 13:29:00 | 显示全部楼层 |阅读模式
6nm chip  finfet IC Yield会很高吗 ?
只做过0.18um~ 0.11um 这类cp yield 99~ 97% 是基本要求 .  但听说三星10nm 60% 就算可  .    advance process leaking  ..function 等各方面问题,
那一般22nm ,  28nm  , 65nm  SOCchip  yield 到底多高 ?  新闻说 tsmc 3nm 60% 就能达标
发表于 2025-3-19 13:50:58 | 显示全部楼层
首先看你设计,是你设计出来的,其次看你们的测试分bin; 同样的GPU算力设计流片,实际能跑4G主频,还是3G主频,甚至2G, 你自己可以分bin的,都用上,良率应该还可以的,至少T是这样子。
当然,你如果只统计能跑4G主频的,那确实良率有限。
发表于 2025-3-19 14:09:05 | 显示全部楼层
mark 回头来看
发表于 2025-3-19 14:22:42 | 显示全部楼层
yield都是跟spec走的
 楼主| 发表于 2025-3-28 12:33:55 | 显示全部楼层
news
Media reports said TSMC has already boosted the yield of its 7nm and 5nm chips to 93.5% and 80%
start of 2023, TSMC's 4nm yield rate was around 70–80%, while Samsung's was still around 50%.
Samsung's current yield rate on 7nm is about 80%
Samsung's first 2nm process yield rates are quite ...
Using semi analysis' die yield calculator for a yield of ~30%
tsmc 7nm  93%
tsmc 5nm  80%
smic 5nm 80% * 0.33
GMT+8, 2025-12-23 08:00 , Processed in 0.021444 second(s), 4 queries , Gzip On, Redis On.
