查看: 1267|回复: 3
求组sentaurus工具swb不运行的问题
发表于 2025-3-12 17:47:34 | 显示全部楼层 |阅读模式
各位彦祖,
   新装一个sentaurus,发现打开project有点卡,然后运行的时候,程序卡在glog.txt ,节点都不染色:
gsub is running on host 'mars' by user 'mars'
Binary '/usr/synopsys/sentaurus/O_2018.06-SP2/bin/../tcad/current/linux64/bin/../lib/gsub0'
Command line options '-verbose -swb_pid 17138 -q local:default -e all /home/mars/STDB/CMOS_180nm'
Current directory '/home/mars'
Some relevant environment variables:
        STROOT=/usr/synopsys/sentaurus/O_2018.06-SP2/bin/..
        STRELEASE=current
        STROOT_LIB=/usr/synopsys/sentaurus/O_2018.06-SP2/bin/../tcad/current/lib
        STDB=/home/mars/STDB
        DATEX=/usr/synopsys/sentaurus/O_2018.06-SP2/bin/../tcad/current/lib/datexcodes.txt
        DISPLAY=:4
Starting swblm daemon...OK
Loading global tool database '/usr/synopsys/sentaurus/O_2018.06-SP2/bin/../tcad/current/lib/glib2/tooldb.tcl'
Project '/home/mars/STDB/CMOS_180nm'
Loading project tool database '/home/mars/STDB/CMOS_180nm/gtooldb.tcl'
   后面就不动了。。。请问这个是什么个情况,哪里还有log可以debug的吗?
另外用Preprocess Tcl Blocks选项,也没有窗口弹出:
来大佬帮助啊啊~谢谢了
 楼主| 发表于 2025-3-13 14:21:01 | 显示全部楼层
顶一个
发表于 2025-4-15 16:52:26 | 显示全部楼层
解决了吗
 楼主| 发表于 2025-6-10 13:46:40 | 显示全部楼层
没有 暂时放弃。。
GMT+8, 2025-12-21 11:26 , Processed in 0.014249 second(s), 4 queries , Gzip On, Redis On.
