查看: 4870|回复: 22
[资料] Cadence RAK : Analog on Top (AoT) Mixed Signal Design Flow
发表于 2025-3-4 08:45:14 | 显示全部楼层 |阅读模式
Analog on Top (AoT) Mixed Signal Design Flow Using Virtuoso Analog and Innovus Digital Platforms: Rapid Adoption Kit (RAK)
There are two methodologies used for implementing Mixed Signal designs. Analog on Top (AOT) refers to the design flow where the top level of the design is represented as a schematic. In the AOT methodology, Virtuoso is typically the environment where the entire top level design is assembled. Digital on Top (DOT) refers to the design flow where the top level of the design is represented as a Verilog netlist. In the DOT methodology, Innovus is typically the environment used for assembling the entire top level design. This tutorial is focused on the AOT flow with Virtuoso as the platform for the top-level design captured in the form of a schematic.
电路档案
链接:https://pan.baidu.com/s/14CVBs9q_BfxFxWdnDaSqug
提取码:g3sf
AoT_Flow.pdf
2.86 MB, 下载次数: 438 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2025-3-4 09:01:03 | 显示全部楼层
谢谢大佬
发表于 2025-3-4 09:19:40 | 显示全部楼层
Thank you
发表于 2025-3-4 09:19:52 | 显示全部楼层
多谢分享
发表于 2025-3-4 09:39:05 | 显示全部楼层
谢谢分享
发表于 2025-3-4 09:40:15 | 显示全部楼层
感谢分享!!!
发表于 2025-3-4 09:55:02 | 显示全部楼层
感谢分享
发表于 2025-3-4 10:23:53 | 显示全部楼层
感谢分享
发表于 2025-3-4 10:55:33 | 显示全部楼层
Thanks for sharing
发表于 2025-3-4 10:59:36 | 显示全部楼层
good data, thanks.
GMT+8, 2025-12-25 12:50 , Processed in 0.018458 second(s), 4 queries , Gzip On, Redis On.
