查看: 860|回复: 2
求助 DVT AI Assistant ?
发表于 2025-2-18 08:04:15 | 显示全部楼层 |阅读模式
国外哪一个最方便, 如 deepseek
The supported providers can be quickly set as follows:
- OpenAI
  Set the environment variable OPENAI_API_KEY=‘…’ before starting the plugin.
- Google AI
  Set the environment variable GOOGLE_AI_API_KEY=‘…’ before starting.
- GitHub Copilot (only in VS Code)
  Install the GitHub Copilot Chat extension.
  Sign-in with your GitHub account.
  When asked, allow to use the Copilot.
- Ollama
  Works out of the box when Ollama runs locally on its default port (11434).
  Otherwise set the environment variable OLLAMA_HOST=‘…’ before starting
发表于 2025-2-18 08:54:11 | 显示全部楼层
文心一言
发表于 2025-2-18 11:37:01 | 显示全部楼层
thanks
GMT+8, 2025-12-18 01:20 , Processed in 0.013473 second(s), 3 queries , Gzip On, Redis On.
