查看: 1780|回复: 3
synopsys license有feature,还是报缺少feature
发表于 2025-2-14 01:04:09 | 显示全部楼层 |阅读模式
cat Synopsys.dat.bak| grep DWC-AMBA-Fabric
INCREMENT DWC-AMBA-Fabric-Source snpslmd 2030.12 30-dec-2030 999
Information: Term was not able to be set up using xterm-256color . Using "xterm" by default instead. (CLE-10)
Information: Reading installation /soft/synopsys/dw_iip_amba_2023.04a/iip/latest/../DW_ahb/2.16a: start (0%) (CMDS-243)
Information: Reading installation /soft/synopsys/dw_iip_amba_2023.04a/iip/latest/../DW_ahb/2.16a: completed (100%) (CMDS-243)
Error: Unable to create workspace due to missing license. One of the following licenses is required: DWC-AMBA-Fabric-Source DesignWare (LIC-19)
Information: Reading installation /soft/synopsys/dw_iip_amba_2023.04a/iip/latest/../DW_ahb_dmac/2.24a: start (0%) (CMDS-243)
Information: Reading installation /soft/synopsys/dw_iip_amba_2023.04a/iip/latest/../DW_ahb_dmac/2.24a: completed (100%) (CMDS-243)
Error: Unable to create workspace due to missing license. One of the following licenses is required: DWC-DMAC-Source DesignWare (LIC-19)
发表于 2025-2-14 09:07:04 | 显示全部楼层
看lic服务器侧提示信息
如果是unsupport,就说缺feature
如果是DENY ,就是没破解好
 楼主| 发表于 2025-2-14 23:25:58 | 显示全部楼层
killwin 发表于 2025-2-14 09:07
看lic服务器侧提示信息
如果是DENY ,就是没破解好 ...
软件有别人提供的服务器上可以跑,我自己生成的license就不能跑
发表于 2025-7-30 00:39:38 | 显示全部楼层
楼主解决了吗,这个问题
GMT+8, 2025-12-21 21:26 , Processed in 0.026452 second(s), 4 queries , Gzip On, Redis On.
