查看: 3073|回复: 12
[求助] innovus求助,不能读取qrc techfile,但文件路径都没错
发表于 2025-1-4 14:47:27 | 显示全部楼层 |阅读模式
#Start tQuantus RC extraction...
#Start building rc corner(s)...
#Number of RC Corner = 2
#Corner slow_corner /mnt/data/projects/zzhen/design/SST202_1/pdk1/pdk_and_QRC/1540BD13SA_QRC_2600/Non_DP/Thick_Cu/3M_8k/max/qrcTechFile 125.000000 (real)
#Corner fast_corner /mnt/data/projects/zzhen/design/SST202_1/pdk1/pdk_and_QRC/1540BD13SA_QRC_2600/Non_DP/Thick_Cu/3M_8k/min/qrcTechFile -40.000000 (real)
#can't read tech file
#ERROR (NREX-94) There are 3 routing layers in design, 0 layers are mapped to techfile. Please check the mapping file.
failed to read db rc_corner
#Rebuild RC model file for all corners.
#WARNING (NRIF-19) Failed to complete extract_rc on Sat Jan  4 14:21:23 2025
true
发表于 2025-1-6 09:06:56 | 显示全部楼层
这是哪一步操作?postroute吗?
 楼主| 发表于 2025-1-6 10:24:24 | 显示全部楼层
haoshiyang 发表于 2025-1-6 09:06
这是哪一步操作?postroute吗?
是route这一步
发表于 2025-1-6 10:26:34 | 显示全部楼层
那应该是cmd文件没有写对
 楼主| 发表于 2025-1-6 10:27:57 | 显示全部楼层
然后那个映射层问题都一一对照过了是一样的
 楼主| 发表于 2025-1-6 10:40:21 | 显示全部楼层
haoshiyang 发表于 2025-1-6 10:26
那应该是cmd文件没有写对
setMultiCpuUsage -localCpu 8
setNanoRouteMode -quiet -routeSelectedNetOnly 0
setNanoRouteMode -quiet -drouteUseMultiCutViaEffort medium
setNanoRouteMode -quiet -routeWithTimingDriven true
setNanoRouteMode -quiet -routeWithSiDriven true
setNanoRouteMode -drouteFixAntenna true
setNanoRouteMode -routeAntennaCellName "SVT_ANT02C"
setNanoRouteMode -routeInsertAntennaDiode true
setNanoRouteMode -quiet -routeInsertDiodeForClockNets true
#setRoutingLayerPreference -layer M3 -minWidth 400
routeDesign -globalDetail
setAnalysisMode -analysisType onChipVariation -cppr both
setDelayCalMode -engine default -siAware true
timeDesign -postRoute
timeDesign -postRoute -hold
#timeDesign -postRoute
#timeDesign -postRoute -hold
saveDesign ${save_path}/6_route.enc
大佬,脚本内容是这样子的
发表于 2025-1-6 15:23:02 | 显示全部楼层
setExtractRCMode  -lefTechFileMap  mapping_file.txt
mapping_file.txt:
extraction_setup \
       -technology_layer_map \
                lef_layer   qrc_layer \
                lef_layer   qrc_layer
 楼主| 发表于 2025-1-6 16:16:13 | 显示全部楼层
mapping_file.txt:
非常感谢,问题已经解决了
发表于 2025-1-22 17:02:46 来自手机 | 显示全部楼层
你好,遇到了相同的问题,设置了qrctech没用啊,你最后是怎么解决的呀
发表于 2025-3-22 23:50:24 | 显示全部楼层
你好,请问你的tech文件是厂商提供的吗
GMT+8, 2025-12-20 13:13 , Processed in 0.018368 second(s), 4 queries , Gzip On, Redis On.
