查看: 1449|回复: 5
[求助] 初学版图设计,做LVS时遇到了问题,求各位大神解答
发表于 2024-12-25 19:52:17 | 显示全部楼层 |阅读模式
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Connectivity errors.
LAYOUT CELL NAME:         inverter
SOURCE CELL NAME:         inverter
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              4         4
Nets:               6         6
Instances:         15         3    *    n18_ckt (4 pins)
                    30         3    *    p18_ckt (4 pins)
                     1         0    *    D (2 pins)
Total Inst:        46         6
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              4         4
Nets:               4         4
Instances:          1         1         _invx3v (4 pins)
Total Inst:         1         1
       * = Number of objects in layout different from number in source.
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               4          4            0            0
   Nets:                4          4            0            0
   Instances:           1          1            0            0    _invx3v
   Total Inst:          1          1            0            0
o Statistics:
   1 passthrough layout net was found.
   1 layout instance was filtered and its pins removed from adjoining nets.
   45 layout mos transistors were reduced to 6.
     39 mos transistors were deleted by parallel reduction.
o Passthrough Layout Nets And Their Ports:
      (Layout nets which are connected only to ports).
   VDD (port: VDD),
o Initial Correspondence Points:
   Ports:        VDD VSS IN OUT
发表于 2024-12-25 20:34:18 | 显示全部楼层
上版图看看
 楼主| 发表于 2024-12-25 20:58:20 | 显示全部楼层
 楼主| 发表于 2024-12-25 21:16:55 | 显示全部楼层
版图
发表于 2024-12-25 22:43:35 | 显示全部楼层
第二张图,pmos为嘛接到VSS,而且没有给B端电位
发表于 2024-12-26 17:22:28 | 显示全部楼层
顶顶
GMT+8, 2025-12-22 14:30 , Processed in 0.018761 second(s), 5 queries , Gzip On, Redis On.
